Hello,
I’ve put my vertex data into a numpy array and done some operations on it. Is there a built in helper function to get the numpy array back into the mesh’s vertex data? thanks
import bpy
import mathutils
import numpy as np
import bmesh
mesh_object = bpy.context.active_object
# Ensure it's a mesh
if mesh_object and mesh_object.type == 'MESH':
mesh = mesh_object.data
#bm = bmesh.new()
#bm.from_mesh(mesh)
# Extract vertex coordinates as NumPy array
positions = np.array([v.co for v in mesh.vertices])
# Extract edges as NumPy array
edges = np.array([(edge.vertices[0], edge.vertices[1]) for edge in mesh.edges])
# Now you have vertices and edges as NumPy arrays
print("Vertices:")
print(positions)
print("\nEdges:")
print(edges)
else:
print("Please select a valid mesh object.")
# Initialise timestep (seconds), vertex weight (kg), gravity
timestep = 0.2
weight = 0.05
gravity = np.array([0,0,-9.8])
print(gravity)
#initialise velocities
velocities = np.zeros_like(positions)
print(velocities)
for i in range(0, 8):
velocities+= timestep*weight*gravity
positions += timestep*velocities
print(positions)
#TODO: update mesh with new positions
