Windows 10, Visual Studio 2017, CUDA 9.1. Using ‘make release’ which used to work a few days ago, I today get an internal compiler error within the file cycles_render.vcxproj:
The description underneath in German basically states that
the program around line 522 in ncolormd.c should be simplified or changed.
Never even heared of such an error message before, so it might well be a sidetrack. I did compile a make full yesterday successfully, will try soon to do so today. Is this compilation error known already?
c:\blender-git\blender\intern\cycles\render\stats.cpp(295): fatal error C1001: An internal error has occurred in the co
mpiler. [C:\blender-git\build_windows_Full_x64_vc15_Release\intern\cycles\render\cycles_render.vcxproj]
cl : Command line error D8040: error creating or communicating with child process [C:\blender-git\build_windows_Full_x6
Have the same 2 errors as @AFWS
Deleted “build_windows_Full_x64_vc15_Release” and redownloaded the windows libs (sometines this helped)
and tried again a “make release 2017”
But got the same erros again
