My project is using kernel_shader_raytrace.ptx with optix 7.3.0 and cycles 3.3.0. We’re trying to use the ambient occlusion node but when loading the ptx file and resolving the nodes the call to optixProgramGroupCreate says it cannot find the __direct_callable__svm_node_ao function in the ptx file and upon searching the ptx file the ambient occlusion code is not in the file. Ambient occlusion does work in cuda for us.
Nothing that effects the ambient occlusion. we do have some small changes which I removed as a test with no luck. Could it be we’re compiling for a too low architecture?
These flags look very different from how Cycles OptiX kernels are built by default.
We don’t use --relocatable-device-code=true, --device-as-default-execution-space, and build ptx with sm_50 as a base level instead of one specialized for a specific new architecture like compute_75.
In fact are these flags even generating ptx code correctly? I think the output might be a combination of ptx and cubin assembled for compute_75. And I would guess OptiX is expecting only ptx.
Ok I got it to work. Yes it was a flags issue. I elminated my architecture flags and put in
nvcc.exe -m64 --ptxas-options="-v" -Wno-deprecated-gpu-targets --use_fast_math -DNVCC -DPOSER_CYCLES=1 -D__KERNEL_EXPERIMENTAL__ -D CCL_NAMESPACE_BEGIN= -D CCL_NAMESPACE_END= -I $(ProjectDir)…\cycles/src/kernel/… -I $(ProjectDir)…\cycles/src/kernel/device/cuda -I"$(ProjectDir)…\Optix SDK 7.3.0\include" -arch=sm_50 --keep-device-functions -o $(OutDir)kernel_optix.ptx --ptx %(FullPath))
I see D__KERNEL_EXPERIMENTAL__ is depreciated so I will remove that.
thanks for the help. Consider this resolved unless I spoke too soon and it comes back to bite me.
