What is the simplest and/or cleanest way of moving a checkbox option to a button in a addon?
I can create a simple operator that calls the boolean, and add a UI button, but the button doesn’t show a active state, like the checkbox does. The button stays gray, but needs to turn blue to show it’s active.
I found some code examples dealing with object properties, but nothing on the above.
If someone has some examples to show, that would be great!
thanks!
rob
