I have a working addon. Now I am adding error traps.
I have some buttons/functions that generate an error when nothing is selected.
All I need to do is, check and see if any MESH objects are selected ( or in edit mode) or its not selected at all.
If not, I want to either catch the error and display a message box panel or do nothing.
This is what I have… but I can’t seem to get it to work.
class SAVT_OT_Operator(bpy.types.Operator):
bl_idname = "viewed3d.select_all_mesh"
bl_label = "Select All Mesh"
bl_description = "Select All Mesh"
current_mode = bpy.context.object.mode
if current_mode == 'EDIT':
def execute(self, context):
bpy.ops.mesh.select_all(action='SELECT')
return {'FINISHED'}
#else:
#nothing
Any help would be appreciated.
You should use the poll
method for checking if an operator is allowed to run.
Here’s a link to nearby documentation: https://docs.blender.org/api/blender2.8/bpy.types.Operator.html?highlight=poll#calling-a-file-selector
Here’s your example if I understood it right
@classmethod
def poll(cls, context):
# Checks to see if there's any active mesh object (selected or in edit mode)
active_object = context.active_object
return active_object is not None and active_object.type == 'MESH' and (context.mode == 'EDIT_MESH' or active_object.select_get())
Okay… this is a great start. Thanks
Also, does this work for the entire plugin or each individual command button.
I have 5+ commands per py file. (i have 3 py files of commands)
If this is only used by the py file only, hoe does it know which command I am checking?
Okay… I figured out for myself… I need one for each operator I want to error trap.
Thanks for the help
I am new to python. Been a VB.NET coder for 15 years.
This is easier, I just don’t know Blenders API yet.
Alright… next issue.
Using this code
@classmethod
#and active_object.type == 'MESH' and (context.mode == 'EDIT_MESH')
Starting Blender, button is inactive (disabled)
Add Object, select object… button becomes enabled (active)
I can execute operator.
But, if I click off or deselect all objects
The button stays enabled. It should be disabled.
This is just supposed to evaluate if object is only selected. Being in EDIT_MESH doesn’t matter in this case.
Iam doing this on the Shade Smooth or Flat, and the toggle button (same as tab key)
Okay. come to realize that this is an expected behavior from the toggle/Shade buttons.
Now, I need to figure how to detect if object is selected and a curve, but not in edit mode.
Next Q.
I have two buttons - Curve to Mesh and Mesh to curve.
They both disabled/enable like they should.
However, if I click off and click one of the buttons i get an error.
I guess because the object is not actually selected.
How do I make sure the object is selected to avoid this error?
CONVERT TO CURVES BUTTON CODE:
class CNVC_OT_Operator(bpy.types.Operator):
bl_idname = "viewed3d.convert_tocurve"
bl_label = "Convert to Curve"
bl_description = "Convert to Curve"
@classmethod
return active_object is not None and active_object.type == 'CURVE'
#and (context.mode == 'EDIT_MESH')
bpy.ops.object.convert(target='MESH')
return {'FINISHED'}
Thanks
Great… figured it out.
@classmethod
obj = context.active_object
objs = context.selected_objects
if len(objs) == 0: return False
#if obj.type == 'MESH': return True
if obj.type == 'CURVE': return True
return False
Now unto my next issue (if there is one)
Okay, I am down to my last issue.
For my Mesh to Curve button.
I can detect that it is a mesh object fine
But, you cannot convert a cube/sphere etc to a curve.
You have to duplicate and edge, separate it from the object then you can convert it to a curve
So, How I do I detect that the mesh object is a cube/sphere etc and return false on the poll?
Basically, How do I know that the object is a 3d obj or just a line edge (like a circle or plane) - aka single line with no faces)
Thanks
Exactly, Blender is behaving as it should, context.mode is still Edit and you have not unset the Active Object, you have only deselected it, not the same thing…
Your poll should be something like:
if all([bool(obj), obj.type == "MESH", obj.mode == "EDIT"]):
This checks that the object exists, object is mesh type and object is in Edit mode - this is different from context.mode being “EDIT”.
You could try: faces = bmesh.faces
where bmesh is the Bmesh from the object, then count these, if the count is not 0 you have faces in the mesh.
EDIT:
Also look at object.select_get()
function, it tells you if an object is selected…
