I’ll try to ping the super guru @brecht.
In previous versions of Cycles I was able to stop the render and change the texture by typing (and make another render after that)
((ccl::ImageTextureNode*)cyclesTex)->filename = newPath;
((ccl::ImageTextureNode*)cyclesTex)->is_float = -1;
shader->need_update = true;
shader->tag_update(scene);
scene->shader_manager->need_update = true;
scene->shader_manager->update_shaders_used(scene);
Notice that the is_float = -1 is the key, unfortunately, this is no longer available;
Now that code without the is_float = -1 seems to have no effect, probably I’m missing an update function but I cannot imagine which one, also there is a need_update variable in Image* but it doesn’t seem to be accessible from the ImageTextureNode.
Thank you in advance for any tip.
