On the GPU page here we get some examples on how to use the GPU shader. Im interested in the last one, the 2d dotted line technique. Yet i would like to use this for a 2d rectangle. I’d like to use it as a select or border selection.
The part how the shader is made is totally strange for me. I dont know where i can find more info about this part.
import bpy
import gpu
from random import random
from mathutils import Vector
from gpu_extras.batch import batch_for_shader
vertex_shader = '''
uniform mat4 u_ViewProjectionMatrix;
in vec3 position;
in float arcLength;
out float v_ArcLength;
void main()
v_ArcLength = arcLength;
gl_Position = u_ViewProjectionMatrix * vec4(position, 1.0f);
fragment_shader = '''
uniform float u_Scale;
in float v_ArcLength;
void main()
if (step(sin(v_ArcLength * u_Scale), 0.5) == 1) discard;
gl_FragColor = vec4(1.0);
coords = [Vector((random(), random(), random())) * 5 for _ in range(5)]
arc_lengths = [0]
for a, b in zip(coords[:-1], coords[1:]):
arc_lengths.append(arc_lengths[-1] + (a - b).length)
shader = gpu.types.GPUShader(vertex_shader, fragment_shader)
batch = batch_for_shader(
shader, 'LINE_STRIP',
{"position": coords, "arcLength": arc_lengths},
def draw():
shader.bind()
matrix = bpy.context.region_data.perspective_matrix
shader.uniform_float("u_ViewProjectionMatrix", matrix)
shader.uniform_float("u_Scale", 10)
batch.draw(shader)
bpy.types.SpaceView3D.draw_handler_add(draw, (), 'WINDOW', 'POST_VIEW')
