is there a way to disable or change the window size limits in blender?.
Thanks in advanced for any tip.
What you mean?
I want a screen capture for window therefore the position and size of the captured window needs to be presice.
I can control it with.
import win32gui as win
w = win.FindWindow(None,'Blender Render')
win.MoveWindow(w,0,0,1920,50,True)
x,y,w,h = win.GetWindowRect(w)
print (x,y,w,h)
but the result is.
0 0 1554 192
The blender window has a min and max size and i want to overcome this limitation but i guess there is no option to disable this limitation.
If you test it by hand you cant make the window smaller than 192 pixels in the y direction.
You may do it the other way round by fixing Blender’s window size & location and then cropping/resizing your screenshot.
https://docs.blender.org/manual/en/latest/advanced/command_line/arguments.html#window-options
I dont get what you mean ?
The command line options do the same thing like the win32gui library and a screenshot is a static picture but i need a interactive realtime window.
Sorry I misread. I thought that this is about a screen capture.
Yes its a realtime screencapture for LED.
The opened window (from a LED controller software) captures and displaye everything what is visible behind it on the LEDs.
