OS: Arch Linux (6.9.9-arch1-1)
Branch: main (a62f1dc6cc)
CMake version: 3.30
Brief description of error: Everything is compiled, but apparently there is a problem when trying to include numpy.
Build logs
Configuring Blender in "/home/sebatt90/Softwares/build_linux" ...
CMake Warning (dev) at build_files/cmake/platform/platform_unix.cmake:491 (find_package):
Policy CMP0167 is not set: The FindBoost module is removed. Run "cmake
--help-policy CMP0167" for policy details. Use the cmake_policy command to
set the policy and suppress this warning.
Call Stack (most recent call first):
CMakeLists.txt:1428 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning at build_files/cmake/macros.cmake:1117 (message):
Python package 'requests' path could not be found in:
'/usr/lib64/python3.11/site-packages/requests',
'/usr/lib64/python3/site-packages/requests',
'/usr/lib64/python3.11/dist-packages/requests',
'/usr/lib64/python3/dist-packages/requests',
'/usr/lib64/python3.11/vendor-packages/requests',
'/usr/lib64/python3/vendor-packages/requests',
The 'WITH_PYTHON_INSTALL_REQUESTS' option will be ignored when installing
Python.
The build will be usable, only add-ons that depend on this package won't be
functional.
CMakeLists.txt:2442 (find_python_package)
Python package 'zstandard' path could not be found in:
'/usr/lib64/python3.11/site-packages/zstandard',
'/usr/lib64/python3/site-packages/zstandard',
'/usr/lib64/python3.11/dist-packages/zstandard',
'/usr/lib64/python3/dist-packages/zstandard',
'/usr/lib64/python3.11/vendor-packages/zstandard',
'/usr/lib64/python3/vendor-packages/zstandard',
The 'WITH_PYTHON_INSTALL_ZSTANDARD' option will be ignored when installing
Python.
functional.
CMakeLists.txt:2448 (find_python_package)
-- Could NOT find OptiX (missing: OPTIX_INCLUDE_DIR) (Required is at least version "7.3.0")
-- OptiX not found, disabling WITH_CYCLES_DEVICE_OPTIX
-- Finding Python Module File: certifi/cacert.pem
CMake Warning at source/blender/python/intern/CMakeLists.txt:160 (message):
Unable to find "certifi/cacert.pem" within "/usr/lib64", this build will
not be able to use bundled certificates with the "ssl" module!
CMake Warning at tests/python/CMakeLists.txt:626 (message):
Disabling render tests because tests folder does not exist at
/home/sebatt90/Softwares/blender_dev/tests/data
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/attributes/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/curve_primitives/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/curves/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/curves/interpolate_curves/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/geometry/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/instance/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/repeat_zone/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/mesh_primitives/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/mesh/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/mesh/extrude/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/mesh/split_edges/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/mesh/triangulate/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/points/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/texture/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/utilities/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/vector/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/mesh/boolean/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/volume/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/mesh/subdivision_tests/ Not Found, disabling test.
-- Directory named /home/sebatt90/Softwares/blender_dev/tests/data/modeling/geometry_nodes/simulation/ not found, disabling tests
-- Configuring done (0.9s)
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
PYTHON_NUMPY_INCLUDE_DIRS (ADVANCED)
used as include directory in directory /home/sebatt90/Softwares/blender_dev/extern/audaspace
CMake Error in extern/audaspace/CMakeLists.txt:
Found relative path while evaluating include directories of "audaspace":
"PYTHON_NUMPY_INCLUDE_DIRS-NOTFOUND"
Found relative path while evaluating include directories of "audaspace-py":
-- Generating done (2.3s)
CMake Generate step failed. Build files cannot be regenerated correctly.
make: *** [GNUmakefile:372: all] Error 1
