I came across the script for WorkSpaceTool
in the Python Templates and thought it would be a good starting point for developing a tool. My end goal is to have a tool which when selected will allow the user to click and drag with the mouse to create a cube. Unforunately, I am finding that WorkSpaceTool
just creates a new instance of my operator for every mouse event and then calls the invoke()
method - even for mouse move events and event if my operator is returning RUNNING_MODAL
. modal()
never gets called.
I can find no information about how WorkSpaceTool
is supposed to be used. Is it possible to use this to start a modal operator running which then interactively handle mouse input?
import bpy
class SimpleOperator(bpy.types.Operator):
"""Tooltip"""
bl_idname = "object.simple_operator"
bl_label = "Simple Object Operator"
def __init__(self):
print("construct SimpleOperator")
def __del__(self):
print("destruct SimpleOperator")
@classmethod
def poll(cls, context):
return context.active_object is not None
def modal(self, context, event):
print("modal evTyp:%s evVal:%s" % (str(event.type), str(event.value)))
context.area.tag_redraw()
if event.type in {'MIDDLEMOUSE', 'WHEELUPMOUSE', 'WHEELDOWNMOUSE'}:
# allow navigation
return {'PASS_THROUGH'}
elif event.type == 'MOUSEMOVE':
return {'RUNNING_MODAL'}
elif event.type == 'LEFTMOUSE':
mouse_pos = (event.mouse_region_x, event.mouse_region_y)
print(" pos %s" % str(mouse_pos))
elif event.type == 'RIGHTMOUSE':
return {'FINISHED'}
def execute(self, context):
print("execute SimpleOperator")
return {'FINISHED'}
print("invoke evTyp:%s evVal:%s" % (str(event.type), str(event.value)))
class MyTool(bpy.types.WorkSpaceTool):
bl_space_type = 'VIEW_3D'
bl_context_mode = 'OBJECT'
# The prefix of the idname should be your add-on name.
bl_idname = "my_template.my_circle_select"
bl_label = "My Circle Select"
bl_description = (
"This is a tooltip\n"
"with multiple lines"
bl_icon = "ops.generic.select_circle"
bl_widget = None
bl_keymap = (
("object.simple_operator", {"type": 'LEFTMOUSE', "value": 'PRESS'},
{"properties": []}),
def draw_settings(context, layout, tool):
props = tool.operator_properties("view3d.select_circle")
layout.prop(props, "mode")
layout.prop(props, "radius")
def register():
bpy.utils.register_class(SimpleOperator)
bpy.utils.register_tool(MyTool, after={"builtin.scale_cage"}, separator=True, group=True)
def unregister():
bpy.utils.unregister_class(SimpleOperator)
bpy.utils.unregister_tool(MyTool, after={"builtin.scale_cage"}, separator=True, group=True)
if __name__ == "__main__":
register()
