I hope my description of the problem is not too weird.
I stumbled more than once across now that you can perform tools just from the editor where you want to perform the operation. Not from another editor type, even when it would make sense. And i ask myself if there is a way to globally access such local operators.
In my current case i wanted to place a little icon button in the topbar and the properties editor to set the brush strength and radius. So that the user can see at the tooltip then, ah this hotkey is assigned to set the radius. The problem is, in the Topbar and Properties Editor the hotkey does not show in the tooltip, which makes my button obsolete then. In the 3D view, where you use the brush, the tooltip does show the hotkey though.
Placing the button into the top bar makes it infact a second tool. It is now in another editor type. I can assign a shortcut to it, and this shortcut gets then created elsewhere in the keymap. Means now i have two independant tools, at least when it comes to the hotkey. It’s the same tool though. And works also the same in the top bar, it sets the radius or the strength of the brush in the 3D view. It just doesn’t use the same hotkey.
So is there a way to access the original hotkey by python from another editor? Or is this impossible by design?
Kind regards
Arunderan
