I’ve got some experience building four branches of Blender for Linux flavours on a daily basis for public consumption - with all static libs for maximum compatibility, no less.
Now, I want to build fluid-mantaflow so that people can start getting familiar with the work being done there with FLIP fluids and other advancements. However, I get an error, much that states that the includes for all things tbb
don’t exist (no such file or directory
). Clearly, though, upon inspection, under ../libs/x84_64/
, there is a tbb
folder with all the includes where they should be. How can this be fixed?
The error is being called by an openvdb file, if that makes a difference.
Without a buildlog it’s gonna be a guessing game, but I’d probably look at the cmakelists.txt for whatever project is generating the errors, and make sure the TBB include path is added to the includes.
So, this is what I get on each failure:
[ 16%] Building CXX object intern/mantaflow/CMakeFiles/bf_intern_mantaflow.dir/intern/manta_pp/omp/fileio/iogrids.cpp.o
/Users/sebbas/Developer/Mantaflow/mantaflowDevelop/mantaflowgit/source/fileio/iogrids.cpp:19:5: warning: "NO_ZLIB" is not defined, evaluates to 0 [-Wundef]
In file included from /home/haig/blender-git/lib/linux_x86_64/openvdb/include/openvdb/tree/Tree.h:43:0,
from /home/haig/blender-git/lib/linux_x86_64/openvdb/include/openvdb/Grid.h:39,
from /home/haig/blender-git/lib/linux_x86_64/openvdb/include/openvdb/openvdb.h:39,
from /Users/sebbas/Developer/Mantaflow/mantaflowDevelop/mantaflowgit/source/fileio/iogrids.cpp:26:
/home/haig/blender-git/lib/linux_x86_64/openvdb/include/openvdb/tree/RootNode.h:50:10: fatal error: tbb/parallel_for.h: No such file or directory
#include <tbb/parallel_for.h>
compilation terminated.
intern/mantaflow/CMakeFiles/bf_intern_mantaflow.dir/build.make:302: recipe for target 'intern/mantaflow/CMakeFiles/bf_intern_mantaflow.dir/intern/manta_pp/omp/fileio/iogrids.cpp.o' failed
make[2]: *** [intern/mantaflow/CMakeFiles/bf_intern_mantaflow.dir/intern/manta_pp/omp/fileio/iogrids.cpp.o] Error 1
CMakeFiles/Makefile2:1915: recipe for target 'intern/mantaflow/CMakeFiles/bf_intern_mantaflow.dir/all' failed
make[1]: *** [intern/mantaflow/CMakeFiles/bf_intern_mantaflow.dir/all] Error 2
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2
I seem to have all the libs statically built just fine. Include folders seem to have everything in place. I’m not sure what else to look for. Clearly, this should work on Linux because I think sebbas is developing on Linux, if I’m not mistaken.
Any ideas?
Still going with check if bf_intern_mantaflow’s CMakeLists.txt has the TBB include dir properly included.
I don’t see a CMakeLists.txt
anywhere within the build directory structure.
Cause they are in the source tree
The only CMakeLists.txt
that looks relevant is the one under /blender/intern/mantaflow/CMakeLists.txt
, which contains:
# ***** BEGIN GPL LICENSE BLOCK *****
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software Foundation,
# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# The Original Code is Copyright (C) 2016, Blender Foundation
# All rights reserved.
# The Original Code is: all of this file.
# Contributor(s): Sebastian Barschkis (sebbas)
# ***** END GPL LICENSE BLOCK *****
set(MANTAVERSION "0.12")
if(WITH_OPENMP)
set(MANTA_PP
intern/manta_pp/omp
add_definitions(-DOPENMP=1)
else()
set(MANTA_PP
intern/manta_pp/tbb
add_definitions(-DTBB=1)
endif()
if(WITH_OPENVDB)
add_definitions(-DOPENVDB=1)
endif()
set(INC
extern
intern/strings
${MANTA_PP}
${MANTA_PP}/fileio
${MANTA_PP}/python
${MANTA_PP}/plugin
${MANTA_PP}/pwrapper
${MANTA_PP}/util
../../source/blender/makesdna
../../source/blender/blenlib
if(WITH_PYTHON)
add_definitions(-DWITH_PYTHON)
endif()
set(INC_SYS
${PYTHON_INCLUDE_DIRS}
${ZLIB_INCLUDE_DIRS}
if(NOT WITH_OPENMP)
list(APPEND INC_SYS
${TBB_INCLUDE_DIRS}
endif()
if(WITH_OPENVDB)
list(APPEND INC_SYS
${BOOST_INCLUDE_DIR}
${OPENEXR_INCLUDE_DIRS}
${OPENVDB_INCLUDE_DIRS}
endif()
set(SRC
intern/manta_python_API.cpp
intern/manta_fluid_API.cpp
intern/FLUID.cpp
extern/manta_python_API.h
extern/manta_fluid_API.h
intern/FLUID.h
intern/strings/fluid_script.h
intern/strings/smoke_script.h
intern/strings/liquid_script.h
${MANTA_PP}/commonkernels.h
${MANTA_PP}/commonkernels.h.reg
${MANTA_PP}/commonkernels.h.reg.cpp
${MANTA_PP}/conjugategrad.cpp
${MANTA_PP}/conjugategrad.h
${MANTA_PP}/conjugategrad.h.reg
${MANTA_PP}/conjugategrad.h.reg.cpp
${MANTA_PP}/edgecollapse.cpp
${MANTA_PP}/edgecollapse.h
${MANTA_PP}/edgecollapse.h.reg
${MANTA_PP}/edgecollapse.h.reg.cpp
${MANTA_PP}/fastmarch.cpp
${MANTA_PP}/fastmarch.h
${MANTA_PP}/fastmarch.h.reg
${MANTA_PP}/fastmarch.h.reg.cpp
${MANTA_PP}/fileio/iogrids.cpp
${MANTA_PP}/fileio/iomeshes.cpp
${MANTA_PP}/fileio/ioparticles.cpp
${MANTA_PP}/fileio/mantaio.h
${MANTA_PP}/fileio/mantaio.h.reg
${MANTA_PP}/fileio/mantaio.h.reg.cpp
${MANTA_PP}/fluidsolver.cpp
${MANTA_PP}/fluidsolver.h
${MANTA_PP}/fluidsolver.h.reg
${MANTA_PP}/fluidsolver.h.reg.cpp
${MANTA_PP}/general.cpp
${MANTA_PP}/general.h
${MANTA_PP}/general.h.reg
${MANTA_PP}/general.h.reg.cpp
${MANTA_PP}/gitinfo.h
${MANTA_PP}/grid.cpp
${MANTA_PP}/grid.h
${MANTA_PP}/grid.h.reg
${MANTA_PP}/grid.h.reg.cpp
${MANTA_PP}/grid4d.cpp
${MANTA_PP}/grid4d.h
${MANTA_PP}/grid4d.h.reg
${MANTA_PP}/grid4d.h.reg.cpp
${MANTA_PP}/kernel.cpp
${MANTA_PP}/kernel.h
${MANTA_PP}/kernel.h.reg
${MANTA_PP}/kernel.h.reg.cpp
${MANTA_PP}/levelset.cpp
${MANTA_PP}/levelset.h
${MANTA_PP}/levelset.h.reg
${MANTA_PP}/levelset.h.reg.cpp
${MANTA_PP}/mesh.cpp
${MANTA_PP}/mesh.h
${MANTA_PP}/mesh.h.reg
${MANTA_PP}/mesh.h.reg.cpp
${MANTA_PP}/movingobs.cpp
${MANTA_PP}/movingobs.h
${MANTA_PP}/movingobs.h.reg
${MANTA_PP}/movingobs.h.reg.cpp
${MANTA_PP}/multigrid.cpp
${MANTA_PP}/multigrid.h
${MANTA_PP}/multigrid.h.reg
${MANTA_PP}/multigrid.h.reg.cpp
${MANTA_PP}/noisefield.cpp
${MANTA_PP}/noisefield.h
${MANTA_PP}/noisefield.h.reg
${MANTA_PP}/noisefield.h.reg.cpp
${MANTA_PP}/particle.cpp
${MANTA_PP}/particle.h
${MANTA_PP}/particle.h.reg
${MANTA_PP}/particle.h.reg.cpp
${MANTA_PP}/plugin/advection.cpp
${MANTA_PP}/plugin/apic.cpp
${MANTA_PP}/plugin/extforces.cpp
${MANTA_PP}/plugin/fire.cpp
${MANTA_PP}/plugin/flip.cpp
${MANTA_PP}/plugin/fluidguiding.cpp
${MANTA_PP}/plugin/initplugins.cpp
${MANTA_PP}/plugin/kepsilon.cpp
${MANTA_PP}/plugin/meshplugins.cpp
# ${MANTA_PP}/plugin/numpyconvert.cpp
${MANTA_PP}/plugin/pressure.cpp
${MANTA_PP}/plugin/ptsplugins.cpp
${MANTA_PP}/plugin/secondaryparticles
${MANTA_PP}/plugin/sndparticles.cpp
${MANTA_PP}/plugin/surfaceturbulence.cpp
# ${MANTA_PP}/plugin/tfplugins.cpp
${MANTA_PP}/plugin/vortexplugins.cpp
${MANTA_PP}/plugin/waveletturbulence.cpp
${MANTA_PP}/plugin/waves.cpp
${MANTA_PP}/pwrapper/manta.h
# ${MANTA_PP}/pwrapper/numpyWrap.cpp
# ${MANTA_PP}/pwrapper/numpyWrap.h
${MANTA_PP}/pwrapper/pclass.cpp
${MANTA_PP}/pwrapper/pclass.h
${MANTA_PP}/pwrapper/pconvert.cpp
${MANTA_PP}/pwrapper/pconvert.h
${MANTA_PP}/pwrapper/pvec3.cpp
${MANTA_PP}/pwrapper/pythonInclude.h
${MANTA_PP}/pwrapper/registry.cpp
${MANTA_PP}/pwrapper/registry.h
${MANTA_PP}/python/defines.py
${MANTA_PP}/python/defines.py.reg
${MANTA_PP}/python/defines.py.reg.cpp
${MANTA_PP}/registration.cpp
${MANTA_PP}/shapes.cpp
${MANTA_PP}/shapes.h
${MANTA_PP}/shapes.h.reg
${MANTA_PP}/shapes.h.reg.cpp
${MANTA_PP}/test.cpp
${MANTA_PP}/timing.cpp
${MANTA_PP}/timing.h
${MANTA_PP}/timing.h.reg
${MANTA_PP}/timing.h.reg.cpp
${MANTA_PP}/turbulencepart.cpp
${MANTA_PP}/turbulencepart.h
${MANTA_PP}/turbulencepart.h.reg
${MANTA_PP}/turbulencepart.h.reg.cpp
${MANTA_PP}/util/integrator.h
${MANTA_PP}/util/interpol.h
${MANTA_PP}/util/interpolHigh.h
${MANTA_PP}/util/matrixbase.h
${MANTA_PP}/util/mcubes.h
${MANTA_PP}/util/quaternion.h
${MANTA_PP}/util/randomstream.h
${MANTA_PP}/util/rcmatrix.h
${MANTA_PP}/util/simpleimage.cpp
${MANTA_PP}/util/simpleimage.h
${MANTA_PP}/util/solvana.h
${MANTA_PP}/util/vector4d.cpp
${MANTA_PP}/util/vector4d.h
${MANTA_PP}/util/vectorbase.cpp
${MANTA_PP}/util/vectorbase.h
${MANTA_PP}/vortexpart.cpp
${MANTA_PP}/vortexpart.h
${MANTA_PP}/vortexpart.h.reg
${MANTA_PP}/vortexpart.h.reg.cpp
${MANTA_PP}/vortexsheet.cpp
${MANTA_PP}/vortexsheet.h
${MANTA_PP}/vortexsheet.h.reg
${MANTA_PP}/vortexsheet.h.reg.cpp
blender_add_lib(bf_intern_mantaflow "${SRC}" "${INC}" "${INC_SYS}")
Seems to point to the tbb directory within the source tree. Don’t know if that’s correct, or not. Don’t even know if I’m looking at the right CMakeLists.txt
, for that matter.
try
if(NOT WITH_OPENMP)
list(APPEND INC_SYS
${TBB_INCLUDE_DIRS}
endif()
if(WITH_OPENVDB)
list(APPEND INC_SYS
${TBB_INCLUDE_DIRS}
endif()
Any clue as to why ${TBB_INCLUDE_DIRS}
was not put there in the first place? I suppose sebbas may not be testing with release-like static libs.
Either way, it’s compiling now, without a hitch (so far).
Thanks for the insights, once again, @LazyDodo!
no idea, not my branch, probably just not a combination of libs he tested.
Yep. It works. Compiling fine, now. Will be posting the build on GraphicAll, now.
