Building Cycles Standalone
I’m trying to build cycles standalone.
After an endless search for libraries i got stuck at 60%.
It looks like make is looking for OpenImageIO 2.1.
I have 2.2 installed.
When I switch back to 2.1 build process stops earlier.
Looks like building needs two versions of the same library.
I searched how to install two versions of the same library but the process is complicated.
Any help ?
Please add the output you see in Terminal, after saving it in text file(s).
Sorry, new users can not upload attachments.
https://www.udrop.com/2jUG/LOG
Finally managed to build this version:
Those interested can download it
https://www.udrop.com/1VLh/cycles
Not sure what libraries needed to make it work in linux anyway.
On Linux, installing the dependencies for building Blender, as described in the Blender wiki helps a lot. (Though I was told it won’t help you in Windows)
Also, disabling some of the build options via cmake command line decreases the needed dependencies. (And potentially makes cycles faster)
