I’ve only recently tried and successfully built Blender on Windows by following the instructions on the wiki.
I would like to know if removing ffmpeg is something trivial or if it’s a complex process that will probably break Blender (it won’t matter to me if this only breaks the video sequencer)
If it’s a simple process, I would like to know if someone can help me by pointing out the files that I need to edit before starting the build process.
allright then i’d run make full nobuild in the blender source folder, to generate the project files, then go into your build folder and run the commands i gave previously to actually build it.
I want to learn how to customize Blender and I just thought this up as a small initial exercise to get my feet wet (I have never compiled anything from code before). I chose ffmpeg specifically because it’s a component (I think) is related to a part of Blender that I never use (video stuff).
Unfortunately I seem to be doing something wrong. After I enter the rebuild command, errors and warnings come up (some errors repeat a couple of times):
Error C2039 'applyRGB': is not a member of 'OpenColorIO_v2_0::Processor' cycles_render C:\blender-git\blender\intern\cycles\render\shader.cpp 397
Error C2664 'void OpenColorIO_v2_0::Config::getDefaultLumaCoefs(double *) const': cannot convert argument 1 from 'float *' to 'double *' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 409
Error C2440 'initializing': cannot convert from 'void *' to 'float *' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 670
Error C2065 'DisplayTransformRcPtr': undeclared identifier bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 747
Error C2061 syntax error: identifier 'DisplayTransformRcPtr' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 747
Error C2653 'DisplayTransform': is not a class or namespace name bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 749
Error C3861 'Create': identifier not found bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 749
Error C2059 syntax error: ')' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 757
Error C2143 syntax error: missing ';' before '{' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 795
Error C2661 'OpenColorIO_v2_0::PackedImageDesc::PackedImageDesc': no overloaded function takes 7 arguments bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 808
Error C2664 'void OpenColorIO_v2_0::ExponentTransform::setValue(const double (&)[4]) noexcept': cannot convert argument 1 from 'const float *' to 'const double (&)[4]' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 881
Error C2039 'setValue': is not a member of 'OpenColorIO_v2_0::MatrixTransform' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 902
Error C2664 'void OpenColorIO_v2_0::MatrixTransform::Scale(double *,double *,const double *)': cannot convert argument 1 from 'float *' to 'double *' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl.cc 912
Error C2259 'OpenColorIO_v2_0::GpuShaderDesc': cannot instantiate abstract class bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl_glsl.cc 614
Error C2248 'OpenColorIO_v2_0::GpuShaderDesc::GpuShaderDesc': cannot access protected member declared in class 'OpenColorIO_v2_0::GpuShaderDesc' bf_intern_opencolorio C:\blender-git\blender\intern\opencolorio\ocio_impl_glsl.cc 614
Error C1083 Cannot open include file: 'pugixml.hpp': No such file or directory (compiling source file C:\blender-git\blender\intern\cycles\graph\node_xml.cpp) cycles_graph C:\blender-git\blender\intern\cycles\util\util_xml.h 22
Error LNK1104 cannot open file '..\..\lib\Debug\bf_usd.lib' blender C:\blender-git\build_windows_Full_x64_vc16_Release\source\creator\LINK 1
Error MSB3073 The command "setlocal
Warning C4062 enumerator 'ID_RECALC_TAG_FOR_UNDO' in switch of enum 'IDRecalcFlag' is not handled bf_depsgraph C:\blender-git\blender\source\blender\depsgraph\intern\depsgraph_tag.cc 242
Warning C4062 enumerator 'ID_RECALC_TAG_FOR_UNDO' in switch of enum 'IDRecalcFlag' is not handled bf_depsgraph C:\blender-git\blender\source\blender\depsgraph\intern\depsgraph_tag.cc 742
Warning MSB8065 Custom build for item "C:\blender-git\build_windows_Full_x64_vc16_Release\CMakeFiles\8b5d56c26bfa623b227a9b4f97891ab5\buildinfo.h_fake.rule" succeeded, but specified output "c:\blender-git\build_windows_full_x64_vc16_release\source\creator\buildinfo.h_fake" has not been created. This may cause incremental build to work incorrectly. buildinfo C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets 240
Here are all the steps I took:
1-
Installed Visual Studio Community 2019 with Desktop Development with C++ Workload // Slik Subversion // Git // cmake
2-
cd C:\blender-git
git clone git://git.blender.org/blender.git -b blender-v2.83-release
3-
cd C:\blender-git\blender
make update
4-
make full nobuild
5-
cd C:\blender-git\build_windows_Full_x64_vc16_Release
rd /s bin (A yes/no prompt comes up, I say yes)
cmake -DWITH_CODEC_FFMPEG=off .
rebuild
Have tried:
-“make update” again to check all libraries are ok
-“git status” to check if my copy of the source is ok
Is there a way to upgrade to 2.83.1 library files without having to download everything again? Or are they just so different that any upgrade would be pointless?
