I’m hoping someone can help me. I’m trying to build Blender on a fresh install of Fedora 28. Unfortunately I’m stuck at the install_deps.sh stage. It gets as far as Numpy, and then I get this:
ModuleNotFoundError: No module named 'setuptools'
ERROR! Numpy-1.15.0 failed to compile, exiting
I’m trying to build the master branch. It looks like it’s trying to use the newly built Python 3.7 to build numpy, and failing because that doesn’t seem to include setuptools.
I’d appreciate any help anyone can give me; please ask if you need any more information.
What would be interesting is finding why it needs to build numpy? I’d expect fedora 28’s 1.14 python3-numpy package to be used, since we only require >= 1.8…
@mont29 it looks like it builds numpy because it’s built Python (which it builds because Fedora 28 has Python 3.6.6):
if [ "$_do_compile_python" = true ]; then
compile_Python
PRINT ""
if [ "$NUMPY_SKIP" = true ]; then
WARNING "Skipping NumPy installation, as requested..."
else
compile_Numpy
fi
fi
What’s interesting is that checking out b07d866cf6d206 (the commit before the libraries were updated), and forcing a build of Python 3.6.2 works. The output of the Python build includes this:
Ok, looks like https://bugs.python.org/issue31652 is the problem. Installing libffi-devel does the trick, so I guess that’s now a dependency if you want to force a Python build on Fedora, and certainly until Fedora update to 3.7.
Same issue here, but install_deps.sh isn’t installing libffi-devel. I put some debug text in at line 3475 and it reaches that point, but doesn’t output any error or a sudo prompt. (running script as a normal user)
