So I build dependencies with > ./blender/build_files/build_environment/install_deps.sh
Everything goes well, then I run :
make -j12 BUILD_CMAKE_ARGS="-U SNDFILE -U PYTHON* -U BOOST -U Boost -U OPENCOLORIO -U OPENEXR -U OPENIMAGEIO -U LLVM -U CYCLES -U OPENSUBDIV -U OPENVDB -U COLLADA -U FFMPEG -U ALEMBIC -U USD -D WITH_CODEC_SNDFILE=ON -D PYTHON_VERSION=3.7 -D WITH_OPENCOLORIO=ON -D OPENCOLORIO_ROOT_DIR=/opt/lib/ocio -D OPENEXR_ROOT_DIR=/opt/lib/openexr -D WITH_OPENIMAGEIO=ON -D OPENIMAGEIO_ROOT_DIR=/opt/lib/oiio -D WITH_CYCLES_OSL=ON -D WITH_LLVM=ON -D LLVM_VERSION=6.0 -D OSL_ROOT_DIR=/opt/lib/osl -D WITH_OPENSUBDIV=ON -D OPENSUBDIV_ROOT_DIR=/opt/lib/osd -D WITH_OPENVDB=ON -D WITH_OPENVDB_BLOSC=ON -D OPENVDB_ROOT_DIR=/opt/lib/openvdb -D BLOSC_ROOT_DIR=/opt/lib/blosc -D WITH_ALEMBIC=ON -D ALEMBIC_ROOT_DIR=/opt/lib/alembic -D WITH_USD=ON -D USD_ROOT_DIR=/opt/lib/usd -D WITH_CODEC_FFMPEG=ON -D FFMPEG_LIBRARIES=‘avformat;avcodec;avutil;avdevice;swscale;swresample;lzma;rt;theora;theoradec;theoraenc;vorbis;vorbisenc;vorbisfile;ogg;x264;openjp2’ -D WITH_XR_OPENXR=ON -D XR_OPENXR_SDK_ROOT_DIR=/opt/lib/xr-openxr-sdk"
Wich is the recommended cmake output from install_deps.sh, but I get:
[ 53%] Linking C static library …/…/…/lib/libbf_draw.a
[ 53%] Built target bf_draw
[ 53%] Linking CXX static library …/…/lib/libextern_ceres.a
[ 53%] Built target extern_ceres
Makefile:182: recipe for target ‘all’ failed
make[1]: *** [all] Error 2
GNUmakefile:299: recipe for target ‘all’ failed
make: *** [all] Error 2
EDIT: Running it with VERBOSE=1 I get the following output:
[ 48%] Built target bf_blenkernel
make -f source/blender/blenlib/CMakeFiles/bf_blenlib.dir/build.make source/blender/blenlib/CMakeFiles/bf_blenlib.dir/depend
make[2]: Entering directory ‘/home/xavier/blender-git/build_linux’
cd /home/xavier/blender-git/build_linux && /usr/bin/cmake -E cmake_depends “Unix Makefiles” /home/xavier/blender-git/blender /home/xavier/blender-git/blender/source/blender/blenlib /home/xavier/blender-git/build_linux /home/xavier/blender-git/build_linux/source/blender/blenlib /home/xavier/blender-git/build_linux/source/blender/blenlib/CMakeFiles/bf_blenlib.dir/DependInfo.cmake --color=
make[2]: Leaving directory ‘/home/xavier/blender-git/build_linux’
make -f source/blender/blenlib/CMakeFiles/bf_blenlib.dir/build.make source/blender/blenlib/CMakeFiles/bf_blenlib.dir/build
[ 48%] Building CXX object source/blender/blenlib/CMakeFiles/bf_blenlib.dir/intern/task_pool.cc.o
cd /home/xavier/blender-git/build_linux/source/blender/blenlib && /usr/bin/c++ -DNDEBUG -DWITH_ASSERT_ABORT -DWITH_OPENGL -DWITH_TBB -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -D__LITTLE_ENDIAN__ -D__MMX__ -D__SSE2__ -D__SSE__ -I/home/xavier/blender-git/blender/source/blender/blenlib -I/home/xavier/blender-git/blender/source/blender/makesdna -I/home/xavier/blender-git/blender/intern/atomic -I/home/xavier/blender-git/blender/intern/eigen -I/home/xavier/blender-git/blender/intern/guardedalloc -I/home/xavier/blender-git/blender/intern/numaapi/include -I/home/xavier/blender-git/blender/extern/wcwidth -isystem /usr/include/freetype2 -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -fuse-ld=gold -fopenmp -std=c++11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -msse2 -O2 -DNDEBUG -o CMakeFiles/bf_blenlib.dir/intern/task_pool.cc.o -c /home/xavier/blender-git/blender/source/blender/blenlib/intern/task_pool.cc
In file included from /usr/include/tbb/flow_graph.h:30:0,
from /usr/include/tbb/tbb.h:53,
from /home/xavier/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:39:
/usr/include/tbb/task.h: In instantiation of ‘tbb::internal::function_task::function_task(const F&) [with F = Task]’:
/usr/include/tbb/task_group.h:100:25: required from ‘void tbb::internal::task_group_base::internal_run(F&) [with F = const Task; Task = tbb::internal::function_task]’
/usr/include/tbb/task_group.h:179:60: required from ‘void tbb::task_group::run(const F&) [with F = Task]’
/home/xavier/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:198:40: required from here
/usr/include/tbb/task.h:930:48: error: use of deleted function ‘Task::Task(const Task&)’
function_task( const F& f ) : my_func(f) {}
/home/xavier/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:97:3: note: declared here
Task(const Task &other) = delete;
source/blender/blenlib/CMakeFiles/bf_blenlib.dir/build.make:1109: recipe for target ‘source/blender/blenlib/CMakeFiles/bf_blenlib.dir/intern/task_pool.cc.o’ failed
make[2]: *** [source/blender/blenlib/CMakeFiles/bf_blenlib.dir/intern/task_pool.cc.o] Error 1
CMakeFiles/Makefile2:5761: recipe for target ‘source/blender/blenlib/CMakeFiles/bf_blenlib.dir/all’ failed
make[1]: *** [source/blender/blenlib/CMakeFiles/bf_blenlib.dir/all] Error 2
make[1]: Leaving directory ‘/home/xavier/blender-git/build_linux’
I have searched on Google but I can’t find any reference, any help will be appreciated
EDIT: Solved it by building a previous version, following another post on this board
git checkout blender-v2.83-release
make update
make
Thank you
