I’m working on T95010 and realize I didn’t pass the cmake argument correctly, then I fix the build command but the build failed at linking bin/shader_builder
on both macOS and Arch Linux.
macOS 12.2.1, make debug ccache ninja BUILD_CMAKE_ARGS="-DWITH_GPU_SHADER_BUILDER=ON"
Summary
Undefined symbols for architecture x86_64:
“_CGAssociateMouseAndMouseCursorPosition”, referenced from:
GHOST_SystemCocoa::setMouseCursorPosition(int, int) in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
GHOST_SystemCocoa::setCursorPosition(int, int) in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
“_CGDisplayCreateUUIDFromDisplayID”, referenced from:
OpenColorIO_v2_0::GetICCProfilePath(unsigned int) in libOpenColorIO.a(SystemMonitor.cpp.o)
“_CGDisplayIOServicePort”, referenced from:
OpenColorIO_v2_0::SystemMonitorsImpl::getAllMonitors() in libOpenColorIO.a(SystemMonitor.cpp.o)
“_CGDisplayMoveCursorToPoint”, referenced from:
“_CGDisplayUnitNumber”, referenced from:
“_CGGetActiveDisplayList”, referenced from:
“_CVMetalTextureCacheCreate”, referenced from:
GHOST_ContextCGL::metalUpdateFramebuffer() in libbf_intern_ghost.a(GHOST_ContextCGL.mm.o)
“_CVMetalTextureCacheCreateTextureFromImage”, referenced from:
“_CVMetalTextureGetTexture”, referenced from:
“_CVOpenGLTextureCacheCreate”, referenced from:
“_CVOpenGLTextureCacheCreateTextureFromImage”, referenced from:
“_CVOpenGLTextureCacheRelease”, referenced from:
“_CVOpenGLTextureGetName”, referenced from:
“_CVOpenGLTextureRelease”, referenced from:
“_CVPixelBufferCreate”, referenced from:
“_CVPixelBufferRelease”, referenced from:
“_ColorSyncDeviceCopyDeviceInfo”, referenced from:
“_FFCreateDevice”, referenced from:
_DARWIN_JoystickRumble in libSDL2.a(SDL_sysjoystick.c.o)
_SDL_SYS_HapticOpenFromService in libSDL2.a(SDL_syshaptic.c.o)
“_FFDeviceCreateEffect”, referenced from:
_SDL_SYS_HapticNewEffect in libSDL2.a(SDL_syshaptic.c.o)
“_FFDeviceGetForceFeedbackCapabilities”, referenced from:
“_FFDeviceGetForceFeedbackProperty”, referenced from:
“_FFDeviceReleaseEffect”, referenced from:
_JoystickDeviceWasRemovedCallback in libSDL2.a(SDL_sysjoystick.c.o)
_SDL_SYS_HapticDestroyEffect in libSDL2.a(SDL_syshaptic.c.o)
“_FFDeviceSendForceFeedbackCommand”, referenced from:
_SDL_SYS_HapticPause in libSDL2.a(SDL_syshaptic.c.o)
_SDL_SYS_HapticUnpause in libSDL2.a(SDL_syshaptic.c.o)
_SDL_SYS_HapticStopAll in libSDL2.a(SDL_syshaptic.c.o)
“_FFDeviceSetForceFeedbackProperty”, referenced from:
_SDL_SYS_HapticSetGain in libSDL2.a(SDL_syshaptic.c.o)
_SDL_SYS_HapticSetAutocenter in libSDL2.a(SDL_syshaptic.c.o)
“_FFEffectGetEffectStatus”, referenced from:
_SDL_SYS_HapticGetEffectStatus in libSDL2.a(SDL_syshaptic.c.o)
“_FFEffectSetParameters”, referenced from:
_SDL_SYS_HapticUpdateEffect in libSDL2.a(SDL_syshaptic.c.o)
“_FFEffectStart”, referenced from:
_SDL_SYS_HapticRunEffect in libSDL2.a(SDL_syshaptic.c.o)
“_FFEffectStop”, referenced from:
_SDL_SYS_HapticStopEffect in libSDL2.a(SDL_syshaptic.c.o)
“_FFIsForceFeedback”, referenced from:
_JoystickDeviceWasAddedCallback in libSDL2.a(SDL_sysjoystick.c.o)
_MacHaptic_MaybeAddDevice in libSDL2.a(SDL_syshaptic.c.o)
“_FFReleaseDevice”, referenced from:
_SDL_SYS_HapticClose in libSDL2.a(SDL_syshaptic.c.o)
“_GetCurrentEventButtonState”, referenced from:
GHOST_SystemCocoa::getButtons(GHOST_Buttons&) const in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
“_IODisplayCreateInfoDictionary”, referenced from:
“_IOHIDDeviceCopyMatchingElements”, referenced from:
“_IOHIDDeviceGetProperty”, referenced from:
“_IOHIDDeviceGetService”, referenced from:
“_IOHIDDeviceGetValue”, referenced from:
_DARWIN_JoystickUpdate in libSDL2.a(SDL_sysjoystick.c.o)
“_IOHIDDeviceRegisterRemovalCallback”, referenced from:
“_IOHIDDeviceScheduleWithRunLoop”, referenced from:
“_IOHIDDeviceUnscheduleFromRunLoop”, referenced from:
_FreeDevice in libSDL2.a(SDL_sysjoystick.c.o)
“_IOHIDElementGetChildren”, referenced from:
_AddHIDElement in libSDL2.a(SDL_sysjoystick.c.o)
“_IOHIDElementGetCookie”, referenced from:
“_IOHIDElementGetLogicalMax”, referenced from:
“_IOHIDElementGetLogicalMin”, referenced from:
“_IOHIDElementGetType”, referenced from:
“_IOHIDElementGetTypeID”, referenced from:
“_IOHIDElementGetUsage”, referenced from:
“_IOHIDElementGetUsagePage”, referenced from:
“_IOHIDManagerClose”, referenced from:
_DARWIN_JoystickQuit in libSDL2.a(SDL_sysjoystick.c.o)
“_IOHIDManagerCreate”, referenced from:
_DARWIN_JoystickInit in libSDL2.a(SDL_sysjoystick.c.o)
“_IOHIDManagerOpen”, referenced from:
“_IOHIDManagerRegisterDeviceMatchingCallback”, referenced from:
“_IOHIDManagerScheduleWithRunLoop”, referenced from:
“_IOHIDManagerSetDeviceMatchingMultiple”, referenced from:
“_IOHIDManagerUnscheduleFromRunLoop”, referenced from:
“_IOHIDValueGetIntegerValue”, referenced from:
“_IOIteratorIsValid”, referenced from:
_SDL_SYS_HapticInit in libSDL2.a(SDL_syshaptic.c.o)
“_IOIteratorNext”, referenced from:
“_IOObjectIsEqualTo”, referenced from:
_MacHaptic_MaybeRemoveDevice in libSDL2.a(SDL_syshaptic.c.o)
_SDL_SYS_JoystickSameHaptic in libSDL2.a(SDL_syshaptic.c.o)
_SDL_SYS_HapticOpenFromJoystick in libSDL2.a(SDL_syshaptic.c.o)
“_IOObjectRelease”, referenced from:
_SDL_SYS_HapticQuit in libSDL2.a(SDL_syshaptic.c.o)
“_IOObjectRetain”, referenced from:
“_IOPSCopyPowerSourcesInfo”, referenced from:
_SDL_GetPowerInfo_MacOSX in libSDL2.a(SDL_syspower.c.o)
“_IOPSCopyPowerSourcesList”, referenced from:
“_IOPSGetPowerSourceDescription”, referenced from:
“_IORegistryEntryCreateCFProperties”, referenced from:
“_IORegistryEntryGetParentEntry”, referenced from:
“_IOServiceGetMatchingServices”, referenced from:
“_IOServiceMatching”, referenced from:
“_LMGetKbdType”, referenced from:
convertKey(int, unsigned short, unsigned short) in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
“_LSSharedFileListCopySnapshot”, referenced from:
_fsmenu_read_system in libbf_editor_space_file.a(fsmenu.c.o)
“_LSSharedFileListCreate”, referenced from:
“_LSSharedFileListItemResolve”, referenced from:
“_NSApp”, referenced from:
-[CocoaAppDelegate applicationDidFinishLaunching:] in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
GHOST_SystemCocoa::handleOpenDocumentRequest(void*) in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
-[CocoaAppDelegate windowWillClose:] in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
GHOST_SystemCocoa::processEvents(bool) in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
GHOST_SystemCocoa::init() in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
GHOST_SystemCocoa::handleWindowEvent(GHOST_TEventType, GHOST_WindowCocoa*) in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
GHOST_WindowCocoa::setOrder(GHOST_TWindowOrder) in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
(maybe you meant: _OBJC_LABEL_PROTOCOL$_NSApplicationDelegate, _OBJC_PROTOCOL$_NSApplicationDelegate )
“_NSBitsPerPixelFromDepth”, referenced from:
GHOST_DisplayManagerCocoa::getDisplaySetting(unsigned char, int, GHOST_DisplaySetting&) const in libbf_intern_ghost.a(GHOST_DisplayManagerCocoa.mm.o)
GHOST_DisplayManagerCocoa::getCurrentDisplaySetting(unsigned char, GHOST_DisplaySetting&) const in libbf_intern_ghost.a(GHOST_DisplayManagerCocoa.mm.o)
“_NSDeviceRGBColorSpace”, referenced from:
GHOST_SystemCocoa::handleDraggingEvent(GHOST_TEventType, GHOST_TDragnDropTypes, GHOST_WindowCocoa*, int, int, void*) in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
“_NSDeviceWhiteColorSpace”, referenced from:
GHOST_WindowCocoa::setWindowCustomCursorShape(unsigned char*, unsigned char*, int, int, int, int, bool) in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_NSFilenamesPboardType”, referenced from:
-[CocoaWindow draggingEntered:] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
-[CocoaWindow performDragOperation:] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
GHOST_WindowCocoa::GHOST_WindowCocoa(GHOST_SystemCocoa*, char const*, int, int, unsigned int, unsigned int, GHOST_TWindowState, GHOST_TDrawingContextType, bool, bool, bool, GHOST_WindowCocoa*) in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_NSInsetRect”, referenced from:
GHOST_WindowCocoa::setProgressBar(float) in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_NSLog”, referenced from:
____ZN3ccl16MetalDeviceQueue7enqueueENS_12DeviceKernelEiRKNS_21DeviceKernelArgumentsE_block_invoke in libcycles_device.a(queue.mm.o)
“_NSSearchPathForDirectoriesInDomains”, referenced from:
GHOST_SystemPathsCocoa::getUserSpecialDir(GHOST_TUserSpecialDirTypes) const in libbf_intern_ghost.a(GHOST_SystemPathsCocoa.mm.o)
GetApplicationSupportDir(char const*, unsigned long, char*, unsigned long) in libbf_intern_ghost.a(GHOST_SystemPathsCocoa.mm.o)
_SDL_GetPrefPath_REAL in libSDL2.a(SDL_sysfilesystem.m.o)
“_NSStringPboardType”, referenced from:
GHOST_SystemCocoa::getClipboard(bool) const in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
GHOST_SystemCocoa::putClipboard(char const*, bool) const in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
“_NSTIFFPboardType”, referenced from:
“_NSTextInputContextKeyboardSelectionDidChangeNotification”, referenced from:
-[CocoaOpenGLView setSystemAndWindowCocoa:windowCocoa:] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
-[CocoaMetalView setSystemAndWindowCocoa:windowCocoa:] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_NSUserNotificationDefaultSoundName”, referenced from:
postNotification() in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_NSWindowWillCloseNotification”, referenced from:
-[CocoaAppDelegate init] in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
-[CocoaAppDelegate dealloc] in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
“_NSZeroPoint”, referenced from:
GHOST_WindowCocoa::endProgressBar() in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_NSZeroRect”, referenced from:
-[CocoaOpenGLView firstRectForCharacterRange:actualRange:] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
-[CocoaMetalView firstRectForCharacterRange:actualRange:] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“OBJC_CLASS$_CAMetalLayer”, referenced from:
objc-class-ref in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“OBJC_CLASS$_NSAlert”, referenced from:
objc-class-ref in libbf_intern_ghost.a(GHOST_ContextCGL.mm.o)
“OBJC_CLASS$_NSApplication”, referenced from:
objc-class-ref in libbf_intern_ghost.a(GHOST_SystemCocoa.mm.o)
“OBJC_CLASS$_NSAttributedString”, referenced from:
“OBJC_CLASS$_NSAutoreleasePool”, referenced from:
objc-class-ref in libbf_intern_ghost.a(GHOST_DisplayManagerCocoa.mm.o)
objc-class-ref in libbf_intern_locale.a(osx_user_locale.mm.o)
“OBJC_CLASS$_NSBezierPath”, referenced from:
“OBJC_CLASS$_NSBitmapImageRep”, referenced from:
“OBJC_CLASS$_NSBundle”, referenced from:
objc-class-ref in libbf_intern_ghost.a(GHOST_SystemPathsCocoa.mm.o)
objc-class-ref in libSDL2.a(SDL_sysfilesystem.m.o)
objc-class-ref in libSDL2.a(SDL_rwopsbundlesupport.m.o)
“OBJC_CLASS$_NSColor”, referenced from:
“OBJC_CLASS$_NSCursor”, referenced from:
“OBJC_CLASS$_NSEvent”, referenced from:
“OBJC_CLASS$_NSFileManager”, referenced from:
“OBJC_CLASS$_NSGraphicsContext”, referenced from:
“OBJC_CLASS$_NSImage”, referenced from:
“OBJC_CLASS$_NSMenu”, referenced from:
“OBJC_CLASS$_NSMenuItem”, referenced from:
“OBJC_CLASS$_NSNotificationCenter”, referenced from:
“OBJC_CLASS$_NSNumber”, referenced from:
“OBJC_CLASS$_NSOpenGLContext”, referenced from:
“OBJC_CLASS$_NSOpenGLPixelFormat”, referenced from:
“OBJC_CLASS$_NSOpenGLView”, referenced from:
OBJC_CLASS$_CocoaOpenGLView in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“OBJC_CLASS$_NSPasteboard”, referenced from:
“OBJC_CLASS$_NSProcessInfo”, referenced from:
objc-class-ref in libcycles_device.a(kernel.mm.o)
“OBJC_CLASS$_NSScreen”, referenced from:
“OBJC_CLASS$_NSString”, referenced from:
objc-class-ref in libbf_blenlib.a(storage_apple.mm.o)
objc-class-ref in libcycles_device.a(device_impl.mm.o)
“OBJC_CLASS$_NSTextInputContext”, referenced from:
“OBJC_CLASS$_NSUserNotification”, referenced from:
“OBJC_CLASS$_NSUserNotificationCenter”, referenced from:
“OBJC_CLASS$_NSView”, referenced from:
OBJC_CLASS$_CocoaMetalView in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“OBJC_CLASS$_NSWindow”, referenced from:
OBJC_CLASS$_CocoaWindow in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“OBJC_METACLASS$_NSOpenGLView”, referenced from:
OBJC_METACLASS$_CocoaOpenGLView in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“OBJC_METACLASS$_NSView”, referenced from:
OBJC_METACLASS$_CocoaMetalView in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“OBJC_METACLASS$_NSWindow”, referenced from:
OBJC_METACLASS$_CocoaWindow in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_TISCopyCurrentKeyboardInputSource”, referenced from:
-[CocoaOpenGLView checkImeEnabled] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
-[CocoaMetalView checkImeEnabled] in libbf_intern_ghost.a(GHOST_WindowCocoa.mm.o)
“_TISCopyCurrentKeyboardLayoutInputSource”, referenced from:
“_TISGetInputSourceProperty”, referenced from:
“_UCKeyTranslate”, referenced from:
“_build_branch”, referenced from:
_make_app_info in libbf_python.a(bpy_app.c.o)
“_build_cflags”, referenced from:
“_build_commit_date”, referenced from:
DocumentExporter::exportCurrentScene() in libbf_collada.a(DocumentExporter.cpp.o)
“_build_commit_time”, referenced from:
“_build_commit_timestamp”, referenced from:
_write_global in libbf_blenloader.a(writefile.c.o)
“_build_cxxflags”, referenced from:
“_build_date”, referenced from:
“_build_hash”, referenced from:
“_build_linkflags”, referenced from:
“_build_platform”, referenced from:
“_build_system”, referenced from:
“_build_time”, referenced from:
“_build_type”, referenced from:
“_iconv”, referenced from:
_avcodec_decode_subtitle2 in libavcodec.a(decode.o)
_getstr8 in libavformat.a(mpegts.o)
boost::locale::impl_posix::mb2_iconv_converter::mb2_iconv_converter(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > const&) in libboost_locale.a(codecvt.o)
boost::locale::impl_posix::mb2_iconv_converter::to_unicode(char const*&, char const*) in libboost_locale.a(codecvt.o)
boost::locale::impl_posix::mb2_iconv_converter::from_unicode(unsigned int, char*, char const*) in libboost_locale.a(codecvt.o)
std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > boost::locale::conv::impl::iconverter_base::real_convert<char, char>(char const*, char const*) in libboost_locale.a(codepage.o)
std::__1::basic_string<wchar_t, std::__1::char_traits<wchar_t>, std::__1::allocator<wchar_t> > boost::locale::conv::impl::iconverter_base::real_convert<wchar_t, char>(char const*, char const*) in libboost_locale.a(codepage.o)
(maybe you meant: boost::locale::impl_posix::mb2_iconv_converter::to_unicode(char const*&, char const*), boost::locale::impl_posix::mb2_iconv_converter::clone() const , boost::locale::impl_posix::mb2_iconv_converter::is_thread_safe() const , boost::locale::impl_posix::mb2_iconv_converter::max_len() const , boost::locale::impl_posix::mb2_iconv_converter::~mb2_iconv_converter() , vtable for boost::locale::impl_posix::mb2_iconv_converter , boost::locale::impl_posix::create_iconv_converter(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > const&) , typeinfo for boost::locale::impl_posix::mb2_iconv_converter , _SDL_iconv_open_REAL , _SDL_iconv_close_REAL , _SDL_iconv_REAL , _SDL_iconv_string , _SDL_iconv_close , boost::locale::impl_posix::mb2_iconv_converter::~mb2_iconv_converter() , boost::locale::impl_posix::mb2_iconv_converter::from_unicode(unsigned int, char*, char const*) , boost::locale::impl_posix::mb2_iconv_converter::mb2_iconv_converter(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > const&) , typeinfo name for boost::locale::impl_posix::mb2_iconv_converter , boost::locale::impl_posix::mb2_iconv_converter::~mb2_iconv_converter() , _SDL_iconv_open , _SDL_iconv , _SDL_iconv_string_REAL )
“_iconv_close”, referenced from:
_avcodec_open2 in libavcodec.a(avcodec.o)
boost::locale::impl_posix::mb2_iconv_converter::~mb2_iconv_converter() in libboost_locale.a(codecvt.o)
boost::locale::conv::impl::iconv_between::open(char const*, char const*, boost::locale::conv::method_type) in libboost_locale.a(codepage.o)
boost::locale::conv::impl::iconv_between::~iconv_between() in libboost_locale.a(codepage.o)
(maybe you meant: _SDL_iconv_close_REAL, _SDL_iconv_close )
“_iconv_open”, referenced from:
boost::locale::conv::impl::convert_between(char const*, char const*, char const*, char const*, boost::locale::conv::method_type) in libboost_locale.a(codepage.o)
(maybe you meant: _SDL_iconv_open_REAL, _SDL_iconv_open )
“_kCVPixelBufferMetalCompatibilityKey”, referenced from:
“_kCVPixelBufferOpenGLCompatibilityKey”, referenced from:
“_kColorSyncCustomProfiles”, referenced from:
“_kColorSyncDeviceDefaultProfileID”, referenced from:
“_kColorSyncDeviceProfileURL”, referenced from:
“_kColorSyncDisplayDeviceClass”, referenced from:
“_kColorSyncFactoryProfiles”, referenced from:
“_kIOMasterPortDefault”, referenced from:
“_kLSSharedFileListFavoriteItems”, referenced from:
“_kTISPropertyInputSourceIsASCIICapable”, referenced from:
“_kTISPropertyUnicodeKeyLayoutData”, referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [bin/shader_builder] Error 1
make[2]: *** [source/blender/gpu/CMakeFiles/shader_builder.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs…
now run: “make install” to copy runtime files and scripts to Blender.app/Contents/Resources/3.2
[100%] Built target blender
make[1]: *** [all] Error 2
make: *** [all] Error 2
Arch Linux, make debug ccache ninja BUILD_CMAKE_ARGS="-DWITH_GPU_SHADER_BUILDER=ON -DWITH_LINKER_MOLD=ON"
Summary
mold: error: undefined symbol: /home/x/git/blender-git/lib/linux_centos7_x86_64/usd/lib/libusd_m.a(mallocHook.cpp.o): __malloc_hook
mold: error: undefined symbol: /home/x/git/blender-git/lib/linux_centos7_x86_64/usd/lib/libusd_m.a(mallocHook.cpp.o): __realloc_hook
mold: error: undefined symbol: /home/x/git/blender-git/lib/linux_centos7_x86_64/usd/lib/libusd_m.a(mallocHook.cpp.o): __memalign_hook
mold: error: undefined symbol: /home/x/git/blender-git/lib/linux_centos7_x86_64/usd/lib/libusd_m.a(mallocHook.cpp.o): __free_hook
collect2: error: ld returned 1 exit status
[5/9] Linking CXX executable bin/blender
ninja: build stopped: subcommand failed.
make: *** [GNUmakefile:329: all] Error 1
Does anyone know how to solve these errors?
