Hi All,
Not sure which channel would be the best one to report this error message
It looks like that this submission git.blender.org - blender.git/commit breaks current master build using enabled “WITH_CYCLES_STANDALONE(_GUI)” options:
.../blender/src/intern/cycles/app/cycles_xml.cpp: In function ‘void ccl::xml_read_shader_graph(ccl::XMLReadState&, ccl::Shader*, OpenImageIO_v2_1::pugi::xml_node)’:
.../blender/src/intern/cycles/app/cycles_xml.cpp:295:63: error: no matching function for call to ‘ccl::OSLShaderManager::osl_node(ccl::ShaderManager*&, std::string&)’
snode = OSLShaderManager::osl_node(manager, filepath);
In file included from .../blender/src/intern/cycles/app/cycles_xml.cpp:34:
.../blender/src/intern/cycles/app/../render/osl.h:96:19: note: candidate: ‘static ccl::OSLNode* ccl::OSLShaderManager::osl_node(ccl::ShaderGraph*, ccl::ShaderManager*, const string&, const string&, const string&)’
static OSLNode *osl_node(ShaderGraph *graph
.../blender/src/intern/cycles/app/../render/osl.h:96:19: note: candidate expects 5 arguments, 2 provided
I guess adding “shader” variable as a first parameter (created on line 213 “ShaderGraph *graph = new ShaderGraph();”) would be the right fix for it.
Regards,
Oleg
