em1
#1
blender 2.8
there is the new timer api.
link
I CAN start the timer with a button (operator) call !
but NOT from load-post hander (in addon) !
# does not work:
def timer_fired():
# do stuff
return 0.5 # seconds
def handler():
bpy.app.timers .register( timer_fired )
def my_register():
bpy.app.handlers .load_post .append( handler )
Maybe the timer has to be marked as persistent.
https://docs.blender.org/api/blender2.8/bpy.app.timers.html#bpy.app.timers.register
(nevertheless this should not be necessary in load_post
handler, will check it)
Quick update: You have to make the handler and the timer persistent currently.
em1
#5
that’s it – thank you !
# solution: make it persistent
from bpy.app.handlers import persistent
@persistent # do not discard, when file changes
def timer_fired():
# do stuff
@persistent
def handler_load_post():
if not bpy.app.timers .is_registered( timer_fired ):
bpy.app.timers .register( timer_fired, first_interval=1.0, persistent=True )
def my_init():
bpy.app.handlers .load_post .append( handler_load_post )
