Hi there,
I built a web-frontend using django that leverages bpy as a blender module and it works well. Now it is time to deply to a cloud env and I baked a docker image.
But I have failures that occur in the image, but not in my test-env.
This typically is a result of missing libs that are assumed to be installed in a “normal” install (even though I operate already fairly barebones Void Linux machines).
But one issue that occurs in the docker image has me stumped, bpy.ops.wm.open_mainfile fails:
In [2]: bpy.ops.wm.open_mainfile(filepath="/base/eevee.blend")
Error: File format is not supported in file '/base/eevee.blend'
RuntimeError Traceback (most recent call last)
<ipython-input-2-cfe4d4c80a28> in <module>
----> 1 bpy.ops.wm.open_mainfile(filepath="/base/eevee.blend")
/opt/conda/envs/qwerty/lib/python3.7/site-packages/2.91/scripts/modules/bpy/ops.py in __call__(self, *args, **kw)
130 ret = _op_call(self.idname_py(), C_dict, kw, C_exec, C_undo)
131 else:
--> 132 ret = _op_call(self.idname_py(), None, kw)
133
134 if 'FINISHED' in ret and context.window_manager == wm:
RuntimeError: Error: File format is not supported in file '/base/eevee.blend'
Any hints or tips ?
thanks, S
