When working in a blender, I ran into one problem. I don’t know, maybe someone has already come across, but the reference or photo on which I want to create a model is blown out. I do not know what this is connected with. I hope for your help.
Dumb question: did you check the color space of the reference image in the properties? Should be set to sRGB
but through Filmic Log it becomes not overexposed. It’s just that I don’t understand this very much and I would like to ask you is it normal or not?
If it’s not a problem, could you share here both the blend file and the image?
sorry i dont know how to send mixed file to you, i just cant, sorry. And the photo itself is
And thanks for trying to figure out my problemsorry for not knowing a lot. For example, how to find and send you this file
Don’t worry, but unfortunately I couldn’t find any solution , with my Blender the image looks as it should be… maybe try to reload the factory settings in File>Defaults, and see what happens when you import the image again
I did as you said, but unfortunately it didn’t help. But if I use Filmic Log to create a model from the image, will my result change?
And thanks again for trying to solve my problem. I am very grateful to you)
