I’ve just run into this trying to integrate Blender as a package in the pipeline of of the studio I’m working at. Having the BLENDER_USER_SCRIPTS and BLENDER_SYSTEM_SCRIPTS as single locations rather than search paths is really not flexible enough for most studio pipelines.
In most studio pipelines, applications and plugins are usually installed individually, and centrally on the network, and an environment is dynamically built at runtime to make sure the application has all it needs to start up. This allows systems like Rez to handle the complex dependencies between different applications, with different versions of software running in parallel, collections of software to be versioned per project, etc.
Usually with other applications (Maya, Houdini, etc) this takes the form of appending all the relevant locations to $HOUDINI_PATH etc, i.e. going through all the various plugins and adding them to the search path.
As an example you can see the level of flexibility you get with Houdini and its ability to customise many of its search paths using environment variables: https://www.sidefx.com/docs/houdini/ref/env.html
Right now there’s only a single addon that we want installed, so I have to abuse BLENDER_USER_SCRIPTS in this way, pointing to that single addon. This won’t work if we get another addon since we can’t add multiple directories to the path.
It would be extremely useful if Blender could interpret these environment variables as search paths with multiple ordered items rather than static directories.
