Before I sumbit a patch on this, Physics/ ‘Force Field’ types.
Should they be in:
- Alpahbetical Order.
- Most used first, then the rest in Alphabetical Order.
- None firsts, the rest in Alphabetical Order.
- Leave As.
Should they be in:
We typically try to first group related things. Then within each it groups it’s usually most used first, or simple to more complex, or the order in which they would typically be used. Alphabetical is used if there is no other order that really makes sense.
