Blender Projects is moving its Git SSH domain to git.blender.org
In order to make several improvements to our infrastructure the Git SSH domain of our Gitea instance will be moved from projects.blender.org to git.blender.org.
:warning: On July 1 2025 projects.blender.org stops working as Git SSH remote :warning:
Read all the instructions below to see how you can resolve issues before the switchover.
To be able to keep using Projects via Git, please change your local remotes to use this new domain.
In the main blender repository, we’ve added functionality to make update that will automatically convert your local git remotes to the right ones.
In other cases, the steps below will most likely suffice:
The example below uses the origin remote and the repository blender/blender. Obviously, for other repositories or remotes you would need to use their respective values:
  1. Open your terminal and change your directory to the root of your repository
  2. Run git remote -v and observe its output
    • If you see:
      origin  [email protected]:blender/blender.git (fetch)
      origin  [email protected]:blender/blender.git (push)
      You’re good! :tada:
    • If you see:
      origin https://projects.blender.org/blender/blender.git (fetch)
      origin https://projects.blender.org/blender/blender.git (push)
      You’re good! :tada: Since you’re using HTTPS, no changes are required.
    • If you see:
      You should change your remote by running
      git remote set-url origin [email protected]:blender/blender.git
  3. Be aware that on the next time you interact with this new remote via Git you will be prompted to accept the server’s key fingerprint again under this domain name. This will look as follows:
    The authenticity of host 'git.blender.org (2a01:4f8:2191:3457::2)' can't be established.
    RSA key fingerprint is SHA256:ny+vcWlA5GVdVJFduVmBIyCthgqmNAXdNShi/QSv//U.
    This host key is known by the following other names/addresses:
    ~/.ssh/known_hosts:10: projects.blender.org
    Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
    Note: It might say git.blender.org (168.119.195.207) when you are connecting via IPv4
For any help or questions related to these changes, please use #devops or message me privately at @bartvdbraak:blender.org.
FAQ
1. Why am I receiving a REMOTE HOST IDENTIFICATION HAS CHANGED! warning?
If you get the message below, you should not panic.
@    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
Please contact your system administrator.
Add correct host key in /home/<user>/.ssh/known_hosts to get rid of this message.
Offending RSA key in /home/<user>/.ssh/known_hosts:1
  remove with:
  ssh-keygen -f '/home/<user>/.ssh/known_hosts' -R 'git.blender.org'
Host key for git.blender.org has changed and you have requested strict checking.
Host key verification failed.
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Blender has a history of using different version control management systems. If you were contributing to Blender in the time when Phabricator was used, you might get this message. In that case, it’s safe to follow the instructions given to remove this fingerprint from your known_hosts file using:
ssh-keygen -f '~/.ssh/known_hosts' -R 'git.blender.org'
For windows users using tortoisegit go to Settings->Remote and edit this guy
For users that have Pageant/plink setup on windows for auth, when you pull with git the first time, it may ask you accept the new host key, but it won’t take any keyboard input… (yeah, i got nothing there) and get stuck, to work around that issue, run plink [email protected] once and accept the key and you should be good to go after that!
Also, I used the following script to change all remotes of all repos on my system:
#!/usr/bin/env bash
# Use current directory if no argument is provided, otherwise use the first argument
BASE_DIR="${1:-$(pwd)}"
# Find all directories containing a .git folder
find "$BASE_DIR" -type d -name ".git" | while read -r gitdir; do
    repo_dir=$(dirname "$gitdir")
    echo "Checking repo: $repo_dir"
    cd "$repo_dir" || continue
    # Get all remote names and URLs
    git remote -v | while read -r name url _; do
        # Check for the specific pattern
        if [[ "$url" =~ ^git@projects\.blender\.org:([^/]+)/([^/]+)\.git$ ]]; then
            org="${BASH_REMATCH[1]}"
            repo="${BASH_REMATCH[2]}"
            new_url="[email protected]:${org}/${repo}.git"
            echo "Updating remote '$name' in $repo_dir"
            git remote set-url "$name" "$new_url"
        fi
    done
done
Source: Sign in - Blender ID - blender.org
If you run it without arguments, it’ll search from your current directory but if you give it an arg it will use that as starting directory.
DISCLAIMER: I’ve only tested this on linux and please read the code before executing.
