This has been happening for the past 4-5 days.
My OS is macOS 10.13.6. I am following these instructions, including updating make
and svn
. Below is the relevant part of the message from make
clang: error: unable to execute command: Segmentation fault: 11
clang: error: clang frontend command failed due to signal (use -v to see invocation)
Apple LLVM version 10.0.0 (clang-1000.10.44.4)
Target: x86_64-apple-darwin17.7.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
clang: note: diagnostic msg: PLEASE submit a bug report to http://developer.apple.com/bugreporter/ and include the crash backtrace, preprocessed source, and associated run script.
[ 69%] Building C object source/blender/draw/CMakeFiles/bf_draw.dir/engines/eevee/eevee_engine.c.o
PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
Preprocessed source(s) and associated run script(s) are located at:
clang: note: diagnostic msg: /var/folders/r7/__q5lzgj65z9vr0ytm6l5gy00000gp/T/node_geo_curve_sample-6972a4.cpp
clang: note: diagnostic msg: /var/folders/r7/__q5lzgj65z9vr0ytm6l5gy00000gp/T/node_geo_curve_sample-6972a4.sh
[ 69%] Building C object source/blender/draw/CMakeFiles/bf_draw.dir/engines/eevee/eevee_lightcache.c.o
clang: note: diagnostic msg: Crash backtrace is located in
clang: note: diagnostic msg: /Users/walkerfinlay/Library/Logs/DiagnosticReports/clang_<YYYY-MM-DD-HHMMSS>_<hostname>.crash
clang: note: diagnostic msg: (choose the .crash file that corresponds to your crash)
make[3]: *** [source/blender/nodes/CMakeFiles/bf_nodes.dir/geometry/nodes/node_geo_curve_sample.cc.o] Error 254
make[2]: *** [source/blender/nodes/CMakeFiles/bf_nodes.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs....
There are also a bunch of warnings, but I don’t think that is the issue.
Here are the files mentioned above, hopefully someone here will be able to make sense of them:
cpp file
sh file
crash file
Thanks for your help!
