just an FYI, building 3.0 (and later versions, I guess) on 32bit archs fails with:
[ 884s] /home/abuild/rpmbuild/BUILD/blender-3.0.0/source/blender/blenlib/intern/string_cursor_utf8.c: In function 'BLI_str_cursor_step_utf8':
[ 884s] /home/abuild/rpmbuild/BUILD/blender-3.0.0/source/blender/blenlib/intern/string_cursor_utf8.c:202:66: error: conversion to 'int' from 'unsigned int' may change the sign of the result [-Werror=sign-conversion]
[ 884s] 202 | (delim_type != cursor_delim_type_utf8(str, maxlen, (size_t)*pos))) {
[ 884s] | ^~~~~~~~~~~~
[ 884s] cc1: some warnings being treated as errors
[ 884s] make[2]: *** [source/blender/blenlib/CMakeFiles/bf_blenlib.dir/build.make:1339: source/blender/blenlib/CMakeFiles/bf_blenlib.dir/intern/string_cursor_utf8.c.o] Error 1
[ 884s] make[2]: Leaving directory '/home/abuild/rpmbuild/BUILD/blender-3.0.0/build'
I know, using Blender as 32bit build somewhat contradicts its purpose, and currently dependent packages like OpenShadingLanguage does fail as well:
[ 121s] /home/abuild/rpmbuild/BUILD/OpenShadingLanguage-1.11.15.0/src/liboslexec/pointcloud.cpp: In member function 'virtual int OSL_v1_11::RendererServices::pointcloud_search(OSL_v1_11::ShaderGlobals*, OpenImageIO_v2_2::ustring, const Vec3&, float, int, bool, size_t*, float*, int)':
[ 121s] /home/abuild/rpmbuild/BUILD/OpenShadingLanguage-1.11.15.0/src/liboslexec/pointcloud.cpp:247:35: error: static assertion failed: Partio ParticleIndex should be the size of a size_t
[ 121s] 247 | static_assert (sizeof(size_t) == sizeof(Partio::ParticleIndex),
[ 121s] | ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[ 121s] /home/abuild/rpmbuild/BUILD/OpenShadingLanguage-1.11.15.0/src/liboslexec/pointcloud.cpp: In member function 'virtual int OSL_v1_11::RendererServices::pointcloud_get(OSL_v1_11::ShaderGlobals*, OpenImageIO_v2_2::ustring, size_t*, int, OpenImageIO_v2_2::ustring, OpenImageIO_v2_2::TypeDesc, void*)':
[ 121s] /home/abuild/rpmbuild/BUILD/OpenShadingLanguage-1.11.15.0/src/liboslexec/pointcloud.cpp:365:35: error: static assertion failed: Partio ParticleIndex should be the size of a size_t
[ 121s] 365 | static_assert (sizeof(size_t) == sizeof(Partio::ParticleIndex),
[ 121s] make[2]: *** [src/liboslexec/CMakeFiles/oslexec.dir/build.make:380: src/liboslexec/CMakeFiles/oslexec.dir/pointcloud.cpp.o] Error 1
Therefor, it’s probably time to give up on it (finally…).
