Blender crashes under TravisCI windows VM
I am trying to get blender working under TravisCI. So far I have been successful in getting linux to work. However when I try and get blender to work under the windows VM environment it crashes out with this complaint:
C:/Users/travis/build/douglaskastle/blender-2.82-nightly/blender.exe: error while loading shared libraries: libsndfile-1.dll: cannot open shared object file: No such file or directory
Has any one seen this before and do you know how to either fix it or bypass it? I am trying to run blender in batch mode so I have no need for the GUI interface or any sound.
I think I have seen this before when I have tried to X forward a linux session of blender back to a windows machine that was running a cygwin X server.
guessing you missed the ‘INSTALL’ stage of building that copies all the required dlls next to the blender binary.
I don’t build blender, just download the base windows release from the website and unzip it.
oh allright, hmmm … can you validate it unpacked properly? the sndfile dll should be sitting right next to the blender.exe file
Let me check, it’s a bit indirect to check these things.
yeah… environments like that generally time vampires to setup, i have a blender build on azure… oh man that was horrid to setup
build for 1.5 hour… oh crap… a typo in my script…
fix… restart build…
1.5 hours later #@%#@ missed a second typo…
OK i did that and it appears that libsndfile-1.dll is side by side with the blender file I use. I also reverted to just called blender to return its version, which should only be a command-line only option, no GUI required.
https://travis-ci.org/douglaskastle/blender-fake-addon/builds/608736558
$ ls ../blender-${BLENDER_VERSION}
1892.80
190BlendThumb64.dll
191GPL-license.txt
192GPL3-license.txt
193LICENSE-bfont.ttf.txt
194LICENSE-bmonofont-i18n.ttf.txt
195LICENSE-droidsans.ttf.txt
196OpenAL32.dll
197Python-license.txt
198SDL2.dll
199api-ms-win-core-console-l1-1-0.dll
200api-ms-win-core-console-l1-2-0.dll
201api-ms-win-core-datetime-l1-1-0.dll
202api-ms-win-core-debug-l1-1-0.dll
203api-ms-win-core-errorhandling-l1-1-0.dll
204api-ms-win-core-file-l1-1-0.dll
205api-ms-win-core-file-l1-2-0.dll
206api-ms-win-core-file-l2-1-0.dll
207api-ms-win-core-handle-l1-1-0.dll
208api-ms-win-core-heap-l1-1-0.dll
209api-ms-win-core-interlocked-l1-1-0.dll
210api-ms-win-core-libraryloader-l1-1-0.dll
211api-ms-win-core-localization-l1-2-0.dll
212api-ms-win-core-memory-l1-1-0.dll
213api-ms-win-core-namedpipe-l1-1-0.dll
214api-ms-win-core-processenvironment-l1-1-0.dll
215api-ms-win-core-processthreads-l1-1-0.dll
216api-ms-win-core-processthreads-l1-1-1.dll
217api-ms-win-core-profile-l1-1-0.dll
218api-ms-win-core-rtlsupport-l1-1-0.dll
219api-ms-win-core-string-l1-1-0.dll
220api-ms-win-core-synch-l1-1-0.dll
221api-ms-win-core-synch-l1-2-0.dll
222api-ms-win-core-sysinfo-l1-1-0.dll
223api-ms-win-core-timezone-l1-1-0.dll
224api-ms-win-core-util-l1-1-0.dll
225api-ms-win-crt-conio-l1-1-0.dll
226api-ms-win-crt-convert-l1-1-0.dll
227api-ms-win-crt-environment-l1-1-0.dll
228api-ms-win-crt-filesystem-l1-1-0.dll
229api-ms-win-crt-heap-l1-1-0.dll
230api-ms-win-crt-locale-l1-1-0.dll
231api-ms-win-crt-math-l1-1-0.dll
232api-ms-win-crt-multibyte-l1-1-0.dll
233api-ms-win-crt-private-l1-1-0.dll
234api-ms-win-crt-process-l1-1-0.dll
235api-ms-win-crt-runtime-l1-1-0.dll
236api-ms-win-crt-stdio-l1-1-0.dll
237api-ms-win-crt-string-l1-1-0.dll
238api-ms-win-crt-time-l1-1-0.dll
239api-ms-win-crt-utility-l1-1-0.dll
240avcodec-58.dll
241avdevice-58.dll
242avformat-58.dll
243avutil-56.dll
244blender.exe
245blender_debug_gpu.cmd
246blender_debug_gpu_glitchworkaround.cmd
247blender_debug_log.cmd
248blender_factory_startup.cmd
249concrt140.dll
250copyright.txt
251jemalloc-license.txt
252libsndfile-1.dll
253msvcp140.dll
254ocio-license.txt
255python37.dll
256readme.html
257swresample-3.dll
258swscale-5.dll
259ucrtbase.dll
260vcomp140.dll
261vcruntime140.dll
262The command "ls ../blender-${BLENDER_VERSION}" exited with 0.
2630.12s$ ../blender-${BLENDER_VERSION}/blender --version
264The command "../blender-${BLENDER_VERSION}/blender --version" exited with 127.
cache.2
265store build cache
2661.28sC:/Users/travis/build/douglaskastle/blender-2.80/blender.exe: error while loading shared libraries: libsndfile-1.dll: cannot open shared object file: No such file or directory
267
hmm what happens if you try
cd  ../blender-${BLENDER_VERSION}
blender --version
Fails but different message on failure
> $ cd ../blender-${BLENDER_VERSION}
> The command "cd ../blender-${BLENDER_VERSION}" exited with 0.
> $ ./blender --version
> The command "./blender --version" exited with 127.
> cache.2
> store build cache
> The script chardetect.exe is installed in 'C:\Users\travis\.cache\blender\blender-2.80-windows64\2.80\python\Scripts' which is not on PATH.
> Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
> C:/Users/travis/build/douglaskastle/blender-2.80/blender.exe: error while loading shared libraries: AVIFIL32.dll: cannot open shared object file: No such file or directory
> nothing changed
That’s a system dll which should be available on windows 2000 and up , weird that it is not found
lets try
dir C:\Windows\System32\\avifil32.dll
to validate the dll exists
echo %path%
to see if the system folders are in the search path
set path=%path%;C:\Windows\System32\
to add it to the path anyhow
blender --version
same as before
It looks like it is run in powershell mode, the regular windows commands don’t work as is, echo %path% just returns %path%
$ dir C:\Windows\System32\\avifil32.dll
The command "dir C:\Windows\System32\\avifil32.dll" exited with 2.
prefix all commands with cmd /c and quote them, so instead of echo %path% use cmd /c "echo %path%"
Is it possible it fell through to prompt? I looks like is is awaiting commands, but it is in remote session I can’t background it.
$ cmd /c "dir C:\\Windows\\System32\\avifil32.dll"
Microsoft Windows [Version 10.0.17134.1006]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\Users\travis\build\douglaskastle\blender-2.80>
yeah… i’m gonna give up, it’s clearly environment related but i lack the time to figure out what is making things unhappy sadly.
No worries, as you said time vampire, I think I am a little further along than when I started. Thanks for the pointers.
one last, try if launching just blender with the cmd /c blender.exe command works
so
cmd /c "blender --version"
Same:
Those i did try using the powershell way:
powershell Start-Process 'blender.exe --version'
It does seem to run, without hanging, but doesn’t return anything to the console. I need to get sysexit’s returned to have my system to work.
I suspect that the travisCI setup for windows is not fit for purpose here yet, shame :frowning:
perhaps
powershell Start-Process -NoNewWindow 'blender.exe --version'
It seems to run, doesn’t hang, but does not return any information to the logging console:
$ powershell Start-Process -NoNewWindow "blender --version"
The command "powershell Start-Process -NoNewWindow "blender --version"" exited with 0.
Feels like it is closer to the answer, but not all the way there
when i run it locally initially it popped up a new window that disappeared in under 200ms, when i added --NoNewWindow the output stayed in my terminal i ran the command from.
this thread on stack overflow may have some more ideas you can try.
