Hi, I got a problem recently on MacOS Mojave when trying to build master branch.
I removed CMakeCache.txt and deleted the ‘lib’ folder with prebuilt MacOS dependencies.
Compiling works fine, only when I start Blender, it crashes right away with message
I also tried to ‘make deps’ to see if maybe the available deps builds were wrong, to no avail.
I had libpng installed with Homebrew and I forced it to remove libpng.
However the issue remains.
libpng warning: Application built with libpng-1.4.12 but running with 1.6.37
Cannot png_create_read_struct
IMB_ibImageFromMemory: unknown fileformat (<splash>)
imb_loadtiff: size < IMB_TIFF_NCB
DDS: trying to read beyond end of stream (corrupt file?)
IMB_ibImageFromMemory: unknown fileformat (<blender icons>)
found bundled python: /Users/some_user/blender/build_darwin/bin/blender.app/Contents/Resources/2.91/python
IMB_ibImageFromMemory: unknown fileformat (<splash screen>)
Thanks for your reply.
When I say I delete lib folder (only in a rare case like this), of course I always run make update so that it fetches the necessary pre-built deps before make again. I mentioned compilation works.
Isn’t make full the same as make deps followed by make ?
Thanks for your help! That final attempt worked at least.
Yes, now that I see the related issues with it, this problem appeared after a recent install of Mono…Crazy bug.
