(Blender Bug?) Chaning Property In Redo Panel Deselects Geometry
This issue has been driving me nuts and if not fixed, makes all my selection add-ons useless.
I’ve done a TON of testing and found when it occurs.
This is how it works:
When you select any geometry with any select operator(bpy or bmesh) and the code is executed by a custom operator, the redo panel will deselect the geometry selected by the script and only leave one unselected.
with%20operator%20se
As you can see the operator is super bare bones, no junk code, yet the issue still occurs.
To confirm that this is a fault with a custom operator, I selected the edges with the same code, just without the operator. And I didn’t run into any issues.
The demo speaks for it self:
without%20operator%20se !
I have no idea how this not already a big issue. I haven’t seen anybody complain about this. But with this behaviour it tells me that it’s a bug. I wish do death that I could fix it, but it seems I can’t.
If anybody has any idea what’s going on, please share it!
Here’s the code for testing:
import bpy
import bmesh
from bpy.types import Operator
class OT_SELECT_WITH_OPERATOR(Operator):
    bl_idname= "view3d.select_with_operator"
    bl_label = "Select With Operator"
    def execute(self, context):
        print('run')
        obj = bpy.context.edit_object
        me = obj.data
        bm = bmesh.from_edit_mesh(me)
        for e in bm.edges:
            e.select = True
        bmesh.update_edit_mesh(me, True)
        return{'FINISHED'}
def register():
    bpy.utils.register_class(OT_SELECT_WITH_OPERATOR)
def unregister():
    bpy.utils.unregister_class(OT_SELECT_WITH_OPERATOR)
if __name__ == "__main__":
    register()
Nevermind, just needed to add:
bl_options = {‘REGISTER’, ‘UNDO’}
under my operator variables
