An Addon I am updating has various layers, it can operate over collections of objects in some cases and on individual objects in others.
I have an AddonPreferences class which is registering fine and accessible and rather than attach other properties to the scene I thought it better to have a PointerProperty held in my Prefs class
It is setup pretty much as follows (trimmed to be illustrative):
class ObjMgr_props(bpy.types.PropertyGroup):
model_source : bpy.props.EnumProperty(
name="Model Source",
description="use the selected object as the source",
items=enum_items,
get=ut.source_getter,
set=ut.source_setter)
def some_setup_method():
prefs = bpy,context.preferences.addons['myaddon'].preferences
ob_props = PointerProperty(
name="object helper settings",
description="settings class for the object helper addon",
type=ObjMgr_props)
prefs.obj_mgr_properties = ob_props
Later this gets used in a draw method of a panel
def draw(self, context):
prefs=get_addon_preferences()
ob_props = prefs.obj_mgr_properties
layout = self.layout
layout.operator("create_models_from_selection")
layout.label(text="Assume selected model is...")
layout.prop(ob_props, 'model_source', expand=True)
At runtime this will fail with a TypeError exception
TypeError: UILayout.prop(): error with argument 1, “data” - Function.data expected a AnyType type, not a tuple()
I tried using the property group directly and got
TypeError: UILayout.prop(): error with argument 1, “data” - Function.data expected a AnyType type, not RNAMetaPropGroup
In 2.79 I have more or less the same construct. instead of having the PointerProperty hanging off of the preferences, it is assigned to bpy.types.Scene; examining bpy.types.Scene.obj_mgr_properties shows it to be of the same form (a tuple of built-in function: pointer property and the associated data). Yet it works without a complaint from layout.prop
Has something changed in the inheritance of the pointer property that is no longer allowing it to work? I I must be missing something here, something to do with the bpy.types space perhaps?
I have tried manual registration, I have tried Jacque’s auto_load and once I worked through the differences in those methods I ended up back at the same issue with UILayout.prop.
Any suggestions would be gratefully received as I suspect code blindness is becoming terminal.
Beq
