I did not know that, cool. You still have the issue of Blender needing to calculate when to render each camera though, but a frame drop down could fix that.
Not sure if this will help, but using a Time node, two math nodes, two value nodes, and a mix node you can create a transition similar something a frame drop-down box would do.
Also, there is a compositor improvements thread here: Compositor improvements
