A hotkey for drag drop centered (0,0,0) into 3D View is needed, because dropping at another point shreds objects with Geometry Nodes having sub objects. The sub objects are in mathematcal relation to the main object, but they all are included at the dropping point. At least all sub objects has to be centered, so it could work as intended.
Strg + LMB or Shift + LMB for centered drop would be a nice solution.
