Hello!
Intro
I was working on a new addon in blender wich will generate an armature that its bones names are the same with name of vertex groups of object and in they are placed in the positions of the heaviest weight in each vertex groups.
Be aware, I used AI and it helped me in so many parts, so it is kind of NOT completely done by me.
Why this addon?
Because sometimes you may download a model that is not rigged but it has very nice vertex groups. As the number of vertex groups are too much, it takes forever to create a rig manually. So this addon does it for you! you select your object and press a button and boom! you got your armature, just parent your object using “Armature Deform” and you are done with rigging it.
I need help
I have made it but it has a problem!
The bones are not at the positions they should be.
For example:
In this image, you can see all of the bones take place around the head, which should take place all over the body, not just head (my model has face bones).
This is the code I wrote:
import bpy
from mathutils import Vector
class OBJECT_OT_create_bones(bpy.types.Operator):
bl_idname = "object.create_bones"
bl_label = "Create Bones"
bl_description = "Create bones with names the same as vertex groups of an object and in the positions of the heaviest weight in vertex groups"
bl_options = {'REGISTER', 'UNDO'}
def execute(self, context):
obj = context.active_object
if obj is None:
self.report({'ERROR'}, "No active object")
return {'CANCELLED'}
# Put the armature object in edit mode
arm_obj = bpy.data.objects.new(obj.name + "_armature", bpy.data.armatures.new(obj.name + "_armature"))
context.scene.collection.objects.link(arm_obj)
context.view_layer.objects.active = arm_obj
bpy.ops.object.mode_set(mode='EDIT')
# Create the bones
for vg in obj.vertex_groups:
bone_name = vg.name
bone = arm_obj.data.edit_bones.new(bone_name)
bone.head = obj.matrix_world @ obj.data.vertices[vg.index].co
bone.tail = bone.head + Vector((0, 0, 1))
# Put the armature object back in object mode
bpy.ops.object.mode_set(mode='OBJECT')
return {'FINISHED'}
class VIEW3D_PT_create_bones_panel(bpy.types.Panel):
bl_idname = "VIEW3D_PT_create_bones_panel"
bl_space_type = 'VIEW_3D'
bl_region_type = 'UI'
bl_category = "Create Bones"
def draw(self, context):
layout = self.layout
row = layout.row()
row.label(text="Create Bones:")
row.operator("object.create_bones", text="Create Bones")
def register():
bpy.utils.register_class(OBJECT_OT_create_bones)
bpy.utils.register_class(VIEW3D_PT_create_bones_panel)
def unregister():
bpy.utils.unregister_class(OBJECT_OT_create_bones)
bpy.utils.unregister_class(VIEW3D_PT_create_bones_panel)
if __name__ == "__main__":
register()
How can I fix this? Can someone help?
