Adding Custom Shader Node
I want to add a new node to the shader editor. my build environment is ready and updated:
Windows 64 Bit
Cmake
VSCode
Visual Studio 2022 installed
Python 3 installed
This are stpest that I did to add the shader:
D:\WIP\Test_018_Blender\blender\source\blender\nodes\shader\nodes\node_shader_mehdi.cc
#include "node_shader_util.hh"
#include "node_shader_register.hh"
namespace blender::nodes::node_shader_mehdi_cc
static void node_declare(NodeDeclarationBuilder &b)
    b.add_input<decl::Shader>("In");
    b.add_output<decl::Shader>("Out");
static int gpu_shader_mehdi(GPUMaterial *mat,
                            bNode *node,
                            bNodeExecData *,
                            GPUNodeStack *in,
                            GPUNodeStack *out)
    return GPU_stack_link(mat, node, "node_mehdi", in, out);
void register_node_type_sh_mehdi()
    namespace file_ns = blender::nodes::node_shader_mehdi_cc;
    static blender::bke::bNodeType ntype;
    sh_node_type_base(&ntype, "ShaderNodeMehdi", SH_NODE_MEHDI);
    ntype.ui_name = "Mehdi";
    ntype.ui_description = "Minimal pass-through example.";
    ntype.nclass = NODE_CLASS_SHADER;
    ntype.add_ui_poll = object_shader_nodes_poll;
    ntype.declare = file_ns::node_declare;
    ntype.gpu_fn = file_ns::gpu_shader_mehdi;
    blender::bke::node_register_type(ntype);
D:\WIP\Test_018_Blender\blender\source\blender\nodes\shader\CMakeLists.txt
set(SRC
  nodes/node_shader_mehdi.cc
D:\WIP\Test_018_Blender\blender\source\blender\nodes\shader\node_shader_register.cc
register_node_type_sh_mehdi();
D:\WIP\Test_018_Blender\blender\source\blender\nodes\shader\node_shader_register.hh
void register_node_type_sh_mehdi();
D:\WIP\Test_018_Blender\blender\source\blender\gpu\shaders\material\gpu_shader_material_mehdi.glsl
/* SPDX-FileCopyrightText: 2019 Blender Authors
 * SPDX-License-Identifier: GPL-2.0-or-later */
void node_mehdi(float val, float width, float center, out float outval)
  outval = 1.0 / (1.0 + pow(2.71828183, -((val - center) * width)));
D:\WIP\Test_018_Blender\blender\source\blender\gpu\CMakeLists.txt
shaders/material/gpu_shader_material_mehdi.glsl
and then build/make the entire project, but when I open Blender, shader node is not created.
In general what is the correct pipeline to add a shader node in Blender?
The functionality of the node is, it hasa shader socket input and will output metallic as rgb.
any idea?! please someone show me some examples/tutorials
In general you can pick the a shader node with a fairly unique name, and then search the code for that name. For example “Gabor:”
$ grep -irl gabor scripts intern source
scripts/templates_osl/gabor_noise.osl
scripts/startup/bl_ui/node_add_menu_shader.py
scripts/startup/bl_ui/node_add_menu_geometry.py
scripts/modules/rna_manual_reference.py
intern/cycles/scene/shader_nodes.h
intern/cycles/scene/shader_nodes.cpp
intern/cycles/blender/shader.cpp
intern/cycles/kernel/CMakeLists.txt
intern/cycles/kernel/osl/shaders/CMakeLists.txt
intern/cycles/kernel/osl/shaders/node_gabor_texture.osl
intern/cycles/kernel/svm/types.h
intern/cycles/kernel/svm/node_types_template.h
intern/cycles/kernel/svm/gabor.h
intern/cycles/kernel/svm/svm.h
source/blender/gpu/CMakeLists.txt
source/blender/gpu/shaders/material/gpu_shader_material_tex_gabor.glsl
source/blender/nodes/shader/node_shader_register.hh
source/blender/nodes/shader/CMakeLists.txt
source/blender/nodes/shader/nodes/node_shader_tex_gabor.cc
source/blender/nodes/shader/node_shader_register.cc
source/blender/blenkernel/BKE_node_legacy_types.hh
source/blender/blenlib/BLI_noise.hh
source/blender/blenlib/intern/noise.cc
source/blender/makesdna/DNA_node_types.h
source/blender/makesrna/intern/rna_nodetree.cc
And that gives you a hint for places to look. Perhaps you are missing scripts/startup/bl_ui/node_add_menu_shader.py in this case.
