Is it possible to access the baked data from a light probe through Blender’s Python API?
In particular I’m hoping to get Spherical Harmonics coefficients for each cell in an Irradiance Volume, but coefficients for a Reflection Cubemap probe would be fine too. I’m assuming that’s stored in a cache somewhere, but digging around in the console (e.g. bpy.context.*) and the source code isn’t getting me anywhere.
Thanks!
ncoder
July 20, 2020, 5:44am
2
Closest I could get is:
bpy.ops.scene.light_cache_bake()
bpy.ops.scene.light_cache_free()
bpy.context.scene.eevee.gi_cache_info
It doesn’t look like there are bindings for python, afaik. Would need a patch?
Suppose someone who’s never tried to expose new APIs in blender would try to do this, any pointers? What would be the right way to do it?
I think that’s correct, yes.
I tried to figure this out, too, but don’t understand C++ well enough to get anywhere with it sorry. There were definitely pointers involved.
I’m pretty sure all of that code is C, anyways
Haha, well, i guess that tells you how far I got on this myself!
By the way, I posted the same suggestion on rightclickselect if anyone would like to upvote it.
ncoder
July 20, 2020, 8:53pm
7
Lol. Yes.
I think Don and I are interested in getting that blender lightprobe data into three.js’s three.js docs . I’ve got all the C/C++ experience required. I’m hesitant to try to put a patch together, as i expect I’ll just make the interface wrong way and my PR will get rejected.
I guess I’m looking for a “sponsor” that would be the right person to review the work who could tell me how they would do it, so that we’re all happy in the end.
Has anyone made any headway on this? Recently started to look into this myself and want to make sure I am not duplicating any work.
@netpro2k no progress on the Blender portion of this, as far as I know. I did write up a draft PR to three.js for light probe volumes defined by interpolated SH values:
mrdoob:dev ← donmccurdy:feat-lightprobevolume
opened 09:26PM - 11 Jan 20 UTC
## Summary
A LightProbeVolume samples diffuse indirect lighting in a scene at… each of several LightProbe locations, then provides approximate diffuse lighting for dynamic objects at any location within that space. The method complements baked lighting and lightmaps — which only support static objects — by providing high-quality lighting for dynamic objects as they move throughout a larger scene. Like lightmaps, LightProbeVolumes can be 'baked' offline and stored, then loaded and applied at runtime very efficiently.
Fixes https://github.com/mrdoob/three.js/issues/16228.
Thanks to @WestLangley, @bhouston, and @richardmonette for helpful discussions and code that contributed to this PR.
## API
Bake:
```javascript
var cubeCamera = new THREE.CubeCamera( 0.1, 100, 256, {
format: THREE.RGBAFormat,
magFilter: THREE.LinearFilter,
minFilter: THREE.LinearFilter
// Renderer output is sRGB. Configure renderTarget accordingly.
cubeCamera.renderTarget.texture.encoding = THREE.sRGBEncoding;
// Generate a light probe volume and populate probes in a 10x3x10 grid. Then
// sample lighting at each probe using the CubeCamera.
var volume = new THREE.LightProbeVolume()
.setFromBounds( new THREE.Box3().setFromObject( scene ), 10, 3, 10 )
.build()
.bake( renderer, scene, cubeCamera );
// Store volume and baked lighting as a small JSON object.
var data = volume.toJSON();
Apply:
```javascript
// Reconstruct the volume with pre-baked lighting.
var volume = new THREE.LightProbeVolume().fromJSON( data );
scene.add( volume );
probe = new THREE.LightProbe();
scene.add( probe );
function render () {
volume.update( mesh, probe.sh );
renderer.render( scene, camera );
Lighting is sampled only at the center of each mesh, and larger objects like terrain and buildings will not receive realistic lighting from a single sample. Shadows are not cast by light probes.
## Unresolved
- [ ] **Per-object SH.** While per-object SH coordinates can be computed, only one "probe" is actually in the scene graph functioning as a light. So only one mesh can receive dynamic lighting. This can be resolved with an API to assign SH coordinates or a light probe to a specific object or material.
- [ ] **Optimize.** Various inefficiencies left as TODO. For example, LightProbeVolumeHelper should use InstancedMesh, and `volume.update()` should search incrementally from the last known cell to improve update times.
- [ ] **Correct baking.** I'm not convinced my "baking" method is quite right, but it looks pretty good. Maybe this could be done offline in other tools.
- [X] **Class structure.** ~~In this demo, LightProbeVolume is in the scene graph but its probes are not (I don't want them all affecting the mesh). I'm open to other ways of structuring this.~~ It's useful for the volume to have position in the scene.
- [x] **Grid volumes.** ~~Should we allow arbitrarily-shaped volumes, or require grid-shaped volumes? Blender and Godot appear to be OK with grids. That would let us omit the Delaunay library (which generates ~5x~ 1.5x more tetrahedra than needed, for a grid?), improving volume creation time. And if (in the future) we want to upload the whole volume's SH coordinates to a GPU texture for sampling in the fragment shader, I think a grid would be necessary. But it is less flexible / optimizable.~~ Grids only, for now.
## Demo
https://raw.githack.com/donmccurdy/three.js/feat-lightprobevolume-build/examples/?q=volume#webgl_lightprobe_volume
