8 June 2026
Announcements
Modules & Projects
- 2026-06-02 Animation & Rigging module meeting
- 2026-06-04 Core Module Meeting
- 2026-06-04 Pipeline & I/O Module Meeting
- 2026-06-04 Triaging Module Meeting
- 2026-06-04 Platforms & Builds module meeting
- 2026-06-05 Project Updates meeting
- 2026-06-08 Viewport & EEVEE module meeting
- 2026-06-08 Grease Pencil Module Meeting Notes
New Features and Changes
Alembic
- Deduplicate data reading between IPolyMesh and ISubD (commit) - (Kévin Dietrich)
Anim
- Pose Slide operators for objects (commit) - (Christoph Lendenfeld)
- Show posing tools in Object Mode (commit) - (Nika Kutsniashvili)
Assets
- Better UX when catalogs in Online Essentials diverge from bundled (commit) - (Sybren A. StĂŒvel)
- Always show âOnlineâ icon (commit) - (Sybren A. StĂŒvel)
- Ignore predefined top-level catalogs (like âCompositingâ) in Add menus (commit) - (Julian Eisel)
- Update compositor catalogs (commit) - (Habib Gahbiche)
- Compositor: Update authors for essential library (commit) - (Habib Gahbiche)
- Update Geometry Nodes asset catalogs (commit) - (Sybren A. StĂŒvel)
- Do not download assets when dragging them (commit) - (Julian Eisel)
- Show builtin libraries in the Preferences (commit) - (Julian Eisel)
- Show banner in asset browser when online access is diabled (commit) - (Julian Eisel)
- Add Preferences option to disable online essentials (commit) - (Julian Eisel)
Compositor
- Use blend name as default filename in File Output node (commit) - (Pablo Vazquez)
- Port Boolean Math node (commit) - (Cristian Ivana)
Core
- Recompute indirect linked tag after file load (commit) - (Jacques Lucke)
- Project Awareness and UI (commit) - (Nathan Vegdahl)
- Add profiling markers for memory usage (commit) - (Sean Kim)
- Profile: Use a grey color for the Default Profile category (commit) - (Jonas Holzman)
Cycles
- oneAPI: Update message when no oneAPI devices are available (commit) - (Nikita Sirgienko)
- Metal: Integrate MTLResidencySets for explicit memory management (commit) - (Michael Jones)
- oneAPI: Increase minimal Intel Linux driver after IGC upgrade (commit) - (Nikita Sirgienko)
- Split OptiX kernels into smaller modules to improve load time (commit) - (Brecht Van Lommel)
EEVEE
- Increase motion blur tests threshold for M1 (commit) - (Clément Foucault)
- Enable the gbuffer lib tests (commit) - (Clément Foucault)
- Add shading_offset to the test blocklist on intel (commit) - (CleÌment Foucault)
- Scene Time node shadow update optimizations (commit) - (Miguel Pozo)
Extensions
- Use consistent tooltip for all online access toggles (commit) - (Julian Eisel)
GPU
- Shader: Add easier way to check unused parameters (commit) - (Clément Foucault)
Geometry Nodes
- Store curves surface data before modifier stack evaluation (commit) - (Hans Goudey)
- Support renaming output sockets for Closure to List directly (commit) - (W_Cloud)
- Move inputs below outputs for Closure To List node (commit) - (W_Cloud)
- Add various profiling markers (commit) - (Hans Goudey)
- Bone Info node Exists output (commit) - (Cartesian Caramel)
- Integrate existing hair nodes and new hair dynamics assets (commit) - (Simon Thommes)
- Remove experimental option for hair dynamics (commit) - (Jacques Lucke)
- Bevel Node (commit) - (Howard Trickey)
- New Sort List node (commit) - (Brady Johnston)
ImBuf
- Implicit sharing for metadata (commit) - (Brecht Van Lommel)
Images
- Refactor OpenEXR API and fix some multi-layer issues (commit) - (Brecht Van Lommel)
Keymap
- Frame active item in TreeView with Mouse Button 4 (commit) - (Nika Kutsniashvili)
LibOverride
- Add a new Outliner âremove override operationâ operator/tool. (commit) - (Bastien Montagne)
- Add initial support for geonodes packed bakes. (commit) - (Bastien Montagne)
Modeling
- Support interpolation of vertex custom data when merging vertices (commit) - (Tariq-Sulley)
- Add snap point functionality to the uv editor (commit) - (Tariq-Sulley)
Nodes
- Donât inherit node width for reroutes with Make Group operator (commit) - (quackarooni)
- Donât draw indirectly linked node groups in menu (commit) - (Jacques Lucke)
- Optimize Four Color Mix Modes (commit) - (Raiko)
Sculpt
- Add profile markers (commit) - (Sean Kim)
Shading
- Use Environment Texture node when drag-drop in World editor (commit) - (Oxicid)
UI
- Use title instead of upper case for quick fluid modifier name (commit) - (Damien Picard)
- Use int to store enum value, avoid float conversion (commit) - (Hans Goudey)
- Paint: Adjust brush âAdvancedâ settings (commit) - (Sean Kim)
- Support refreshing sub-menus (commit) - (Julian Eisel)
- Reorder context menu in Nodes editors (commit) - (Eitan Traurig)
- Right click for asset/file browser context menu with right click select (commit) - (Julian Eisel)
- Add missing Copy/Paste icons (commit) - (Eitan Traurig)
- Reorganize context and âKeyâ menus in Dope Sheet (commit) - (Eitan Traurig)
- Add missing icons in context and âObjectâ menus in 3D viewport (commit) - (Eitan Traurig)
- Improve tooltips for shape key operators and properties (commit) - (Nika Kutsniashvili)
- Improve view item dragdrop near edges (commit) - (Pratik Borhade)
VR
- Location Scouting (commit) - (Jonas Holzman)
VSE
- Add width and height parameter to Solid Color Strips (commit) - (AleĆĄ JelovÄan)
- Reorganize and clean up context menu (commit) - (John Kiril Swenson)
Vulkan
- Synchronization issues when uploading CPU data to pool texture (commit) - (Jeroen Bakker)
WM
- Prevent Selection Operators From Overriding Operator Repeat (commit) - (Tariq-Sulley)
Weight Paint
- Update default settings and bundled assets (commit) - (Sean Kim)
Weekly Reports
- Aaron Carlisle
- Alaska
- Bart van der Braak
- Bastien Montagne
- Campbell Barton
- Casey Bianco-Davis
- Christoph Lendenfeld
- Clément Foucault
- Dalai Felinto
- Falk David
- Guillermo Venegas
- Habib Gahbiche
- Hans Goudey
- Jacques Lucke
- Jeroen Bakker
- Jesse Yurkovich
- John Swenson
- Jonas Holzman
- Julian Eisel
- JulienDuroure
- Lukas Tönne
- Kévin Dietrich
- Mark van de Ruit
- Martijn Versteegh
- Miguel Pozo
- Nathan Vegdahl
- Nika Kutsniashvili
- Omar Emara
- Pablo Vazquez
- Philipp Oeser
- Pratik Borhade
- Richard AntalĂk
- Sean Kim
- Sebastian Herholz
- Sergey Sharybin
- Sybren StĂŒvel
- Tariq Sulley
- Thomas Dinges
- Weizhen Huang
- Wu Yiming
