6 October 2025
6 October 2025
Welcomes
Announcements
  • Aras Pranckevičius has accepted responsibility of the Sequencer module owner! The module page has been updated, showing the state and dynamics in the module.
Modules & Projects
New Features and Changes
Anim
  • Make it easier to convert from legacy to current Action API (commit) - (Sybren A. Stüvel)
  • Remove legacy pose library conversion (commit) - (Sybren A. Stüvel)
  • Move “Copy Global Transform” extension to internal scripts (commit) - (Nika Kutsniashvili)
  • Remove deprecated XYZ_TO_RGB flag on keyframe_insert() (commit) - (Nathan Vegdahl)
Attributes
  • Make id attribute generic instead of built-in (commit) - (Jacques Lucke)
Blenloader
  • Stable pointers in .blend files (commit) - (Jacques Lucke)
Color Management
  • Save and load HDR images with 203 nits (commit) - (Brecht Van Lommel)
  • Update for new extended sRGB naming conventions in OCIO (commit) - (Brecht Van Lommel)
  • Support build against OpenColorIO 2.5.0 (commit) - (Brecht Van Lommel)
Compositor
  • Make a distinction between inputs and passes (commit) - (Omar Emara)
  • “Copy” button duplicates node tree (commit) - (Habib Gahbiche)
  • UI: Inline sockets (commit) - (Pablo Vazquez)
Curves
  • Numerically robust curve tangents (commit) - (MattiasF)
Cycles
  • Support printf in Metal 15.0 (commit) - (Weizhen Huang)
  • Specialization constants for Embree/SYCL (commit) - (Stefan Werner)
  • oneAPI: Add new arch codes for upcoming Intel hardware (commit) - (Nikita Sirgienko)
Deps
  • Library changes for Blender 5.0 (commit) - (Thomas Dinges)
Draw
  • Re-enable Handle Ranges optimizations (commit) - (Miguel Pozo)
Essentials Assets
  • Duplicate Separate/Combine Cylindrical/Spherical assets for shading and compositing (commit) - (Simon Thommes)
Functions
  • Avoid triggering multi-threading with too few tasks (commit) - (Jacques Lucke)
GPU
  • Improve shader dependency logger (commit) - (Clément Foucault)
  • ShaderCreateInfo: Add convenience ResourceString (commit) - (Clément Foucault)
  • Remove support for matrices and arrays in shader interfaces (commit) - (Clément Foucault)
  • Move gl_FragStencilRefARB to be scanned and added to created info (commit) - (Clément Foucault)
Geometry Nodes
  • New Join Bundle Node (commit) - (Brady Johnston)
  • Improve warning panel title (commit) - (Jacques Lucke)
  • Adjustments to Essentials assets (commit) - (Simon Thommes)
  • Update bundles hair nodes assets for Blender 5.0 (commit) - (Simon Thommes)
  • Field to Grid Node (commit) - (Hans Goudey)
  • Add volume grid name search (commit) - (Hans Goudey)
  • Add OpenVDB grid operators (commit) - (Brady Johnston)
  • Set Grid Transform (commit) - (Brady Johnston)
  • Volume grid Prune and Voxelize nodes (commit) - (Hans Goudey)
  • Set Grid Background node (commit) - (Hans Goudey)
  • Optimize Sample Grid Index node (commit) - (Jacques Lucke)
  • Change Sample Grid node class (commit) - (Brady Johnston)
  • Optimize Sample Grid node (commit) - (Jacques Lucke)
  • Add Voxel Index node (commit) - (Jacques Lucke)
  • Bring Volume nodes out of experimental (commit) - (Brady Johnston)
  • Optimize active gizmo detection (commit) - (Jacques Lucke)
  • Support renaming items in Field to Grid node (commit) - (Jacques Lucke)
  • Create vector socket when linking color to Grid to Field node (commit) - (Jacques Lucke)
  • Remove default item in Field to Grid node (commit) - (Jacques Lucke)
Grease Pencil
  • Add new Corner Types (commit) - (Casey Bianco-Davis)
  • Add Set Corner Type to the point context menu. (commit) - (Casey Bianco-Davis)
IO
  • Update FBX im-/exporter to use the current Action API (commit) - (Sybren A. Stüvel)
Lighting
  • Update bundled MatCap assets (commit) - (Julien Kaspar)
Mesh
  • Handle free custom normals properly for object joining (commit) - (Hans Goudey)
Modifiers
  • Add icons to remaining modifier assets in Generate category (commit) - (Simon Thommes)
Node Wrangler
  • Fixes for Save Viewer operator (commit) - (Damien Picard)
Nodes
  • New operator to join Group Input nodes (commit) - (Jacques Lucke)
  • Remove “Swap” menu from editor header (commit) - (quackarooni)
  • Support optional labels for group inputs (commit) - (Jacques Lucke)
  • Support searching for group inputs (commit) - (Jacques Lucke)
  • Add versioning to set new optional label flag for existing menu sockets (commit) - (Jacques Lucke)
  • Unify add menus (commit) - (Habib Gahbiche)
  • Further tweaks to add menu for shaders (commit) - (Brecht Van Lommel)
  • Show node editor context path also without a node tree (commit) - (Brecht Van Lommel)
  • UI: Center Define Signature in Bundle nodes (commit) - (Pablo Vazquez)
  • Rename “Fac” sockets to “Factor” (commit) - (Brecht Van Lommel)
  • Add icon and separate “New Group” operators (commit) - (quackarooni)
  • Remove redudant “Object” label in Texture Coordinate node (commit) - (quackarooni)
OpenXR
  • VR Advanced Locomotion Phase 1 (commit) - (hogan.mastanduno)
Paint
  • Add asserts for BKE_brush_curve_strength (commit) - (Sean Kim)
RNA
  • Add callback to support dynamic property ui name (commit) - (Jacques Lucke)
Shader Nodes
  • Support Menu Switch node (commit) - (Jacques Lucke)
  • Default to 0 iterations for invalid Repeat Zones (commit) - (Miguel Pozo)
Spreadsheet
  • Show volume grid stats (commit) - (Jacques Lucke)
UI
  • Interleave essentials modifiers in “Generate” menu (commit) - (Hans Goudey)
  • Grey out ‘Show Object Origins’ option in paint modes (commit) - (Sean Kim)
  • Add dropdown toggle for grease pencil pressure curves (commit) - (Sean Kim)
  • Add preset curve buttons for curve mapping template (commit) - (Sean Kim)
  • Update editor descriptions (commit) - (Pablo Vazquez)
  • Show preset controls for brush strength, size, and jitter curves (commit) - (Sean Kim)
  • Do not use TitleCase in tooltips (commit) - (Pablo Vazquez)
  • Change volume grid type name ‘Float Vector’ to ‘Vector’ (commit) - (Brady Johnston)
  • Remove the Timeline (commit) - (Christoph Lendenfeld)
  • Icons: Add icon for Sequencer Strip Modifier (commit) - (Pablo Vazquez)
  • Icons: Flip direction of looking-glass icon (commit) - (Pablo Vazquez)
  • Show a more useful error when attempting to “Join” faces (commit) - (Campbell Barton)
  • Hide RNA properties that expand into themselves in the outliner (commit) - (Campbell Barton)
  • Color Axes in 3D/2D Cursor (commit) - (Pablo Vazquez)
  • Add missing icons for Undo/Redo in Edit menu (commit) - (Pablo Vazquez)
  • Slightly widen some popovers (commit) - (Pablo Vazquez)
  • Theme: Update Curves Handle Type colors (commit) - (Casey Bianco-Davis)
UV
  • Move on Axis selected UVs operator (commit) - (Eitan Traurig)
UV Sculpt
  • Rename strength_curve and curve_preset (commit) - (Sean Kim)
VSE
  • Story Tools: Sync object modes when switching scenes (commit) - (Falk David)
  • Remove transform effect (commit) - (Richard Antalik)
  • Sound pitch correction (commit) - (Kace)
  • Move Strip properties to Properties editor (commit) - (Richard Antalik)
Vulkan
  • Streaming Buffers (commit) - (Jeroen Bakker)
Wayland
  • Lower the requirement for the xdg_output_manager for Rocky8 (commit) - (Campbell Barton)
Weekly Reports
Google Summer of Code - Final Report
