29 June 2026
29 June 2026
Modules & Projects
New Features and Changes
Anim
  • Add “Align to Transform Orientation” to armature pose mode (commit) - (RedMser)
Compositor
  • Improve GPU playback performance (commit) - (Omar Emara)
  • Avoid redundant copies in cached images (commit) - (Omar Emara)
  • Add Bit Math node (commit) - (Criss-Ivana)
  • Make Inpaint boundary detection more robust (commit) - (Omar Emara)
Core
  • Increase maximum number of open file handles (commit) - (Brecht Van Lommel)
Cycles
  • Show devices with outdated drivers as disabled in preferences (commit) - (Nikita Sirgienko)
  • Simplify shadow evaluation for homogeneous volume (commit) - (Weizhen Huang)
  • Skip evaluating volume emission for shadows (commit) - (Weizhen Huang)
  • Skip evaluating emission for volume extinction (commit) - (Weizhen Huang)
  • Swap volume exit entry instead of shifting all entries (commit) - (Weizhen Huang)
  • Remove backward motion pass from Denoising Data passes (5.2 only) (commit) - (Brecht Van Lommel)
  • Use identity motion transforms to avoid numerical inaccuracies (commit) - (Christoph Neuhauser)
EEVEE
  • Remove limit of 8 object attribute per material (commit) - (ClĂ©ment Foucault)
  • Add support for normal map node Base option (commit) - (Clément Foucault)
  • Add placeholder for Cycles blocklist (commit) - (Clément Foucault)
  • Combine Minv, T matrices in LTC disk evaluation (commit) - (Mark van de Ruit)
Geometry Nodes
  • NURBS input nodes (commit) - (quackarooni)
  • Skip mixing bake states with zero factor (commit) - (Hans Goudey)
  • Add dynamics assets back into the Simulation catalog (commit) - (Lukas Tönne)
UI
  • Use Action Constraint Icon (commit) - (Christoph Lendenfeld)
  • Page Scroll for views (commit) - (Pratik Borhade)
VSE
  • Update startup template (commit) - (Pratik Borhade)
Vulkan
  • Make default (commit) - (Jeroen Bakker)
glTF
  • Enable Animation Pointer for all animation mode export (commit) - (Julien Duroure)
  • Performance enhancement for material (commit) - (Julien Duroure)
Weekly Reports
