27 May 2024
Modules & Projects
- 2024-05-21 Compositor meeting notes
- 2024-05-21 Sequencer meeting notes
- 2024-05-23 - Extensions Project
- 2024-05-24 Animation & Rigging module meeting
- 2024-05-27 EEVEE/Viewport Module Meeting
New Features and Changes
Anim
- Pose Library - Allow blending flipped from the context menu (commit) - (Christoph Lendenfeld)
Collada
- Mark the I/O operators as legacy in the UI. (commit) - (Bastien Montagne)
Compositor
- Optimize Fog Glow glare code (commit) - (Omar Emara)
EEVEE-Next
- Use PDF instead of BSDF for denoising (commit) - (CleÌment Foucault)
- Volume Light-Probe (commit) - (Clément Foucault)
- World: Add shadow options (commit) - (Clément Foucault)
- Improve shadow map filter (commit) - (CleÌment Foucault)
- Shadow: Remove per light resolution scale (commit) - (Clément Foucault)
- Expose Fast GI ray and step count (commit) - (Clément Foucault)
GPv3
- Allow re-filling an area by ignoring fill materials (commit) - (Lukas Tönne)
- Python API additions to layer, layers, layer_groups (commit) - (Sietse Brouwer)
- Consider layer transform in
radius_from_input_sample
(commit) - (Falk David) - Change active node after selecting group in outliner (commit) - (Pratik Borhade)
Geometry Nodes
- Treat rotation as vector data type in link-drag-search in some nodes (commit) - (Iliya Katueshenock)
- Add Active Element tool node (commit) - (Colin Basnett)
Mesh
- Points index buffer improvement (commit) - (Hans Goudey)
- Avoid calculating vertex normals for drawing flat-shaded meshes (commit) - (Hans Goudey)
Nodes
- Change node auto offset default from 80 to 40 (commit) - (Jacques Lucke)
- Make new frame node child of common parent of selected nodes (commit) - (Jacques Lucke)
- Add descriptions for why links are invalid (commit) - (Jacques Lucke)
- Avoid removing link when inserting incompatible node (commit) - (Jacques Lucke)
- Improve tooltip for extend-sockets (commit) - (Iliya Katueshenock)
Preference
- Add option allow internet access (commit) - (Campbell Barton)
Realtime Compositor
- Implement Fog Glow Glare node (commit) - (Omar Emara)
Subdiv
- Simplify loose edge subdivision neighbor retrieval (commit) - (Hans Goudey)
- Simplify GPU subdivision loose geometry handling (commit) - (Hans Goudey)
Support âAdd â Image â Mesh Planeâ as a built-in operator
- Support âAdd â Image â Mesh Planeâ as a built-in operator (commit) - (Campbell Barton)
UI
- Aligned Mouse Event Icons (commit) - (Harley Acheson)
- Slight Adjustment to Status Bar Mouse Event Icon Spacing (commit) - (Harley Acheson)
- Make âText not foundâ report not a warning (commit) - (Pablo Vazquez)
- Edge Slide Comments (commit) - (Harley Acheson)
- Move Normal Edit and Weighted Normal modifiers to âNormalsâ menu (commit) - (Hans Goudey)
- Outliner Ctrl-F To Start Filter (commit) - (Harley Acheson)
- Order âNetworkâ after âOS Settingsâ in the System preferences (commit) - (Campbell Barton)
- Donât expand sub-trees in Outliner âUnused Dataâ display mode (commit) - (Julian Eisel)
- Remove Outliner element collapse chevron for empty scene elements (commit) - (Julian Eisel)
USD
- Read and write custom attributes for Curves (commit) - (Jesse Yurkovich)
- Use nodes for alpha-clip behavior instead of material properties (commit) - (Jesse Yurkovich)
- Added option to specify types of XForm ops written. (commit) - (Charles Wardlaw)
- Filtering option for types to export (commit) - (Charles Wardlaw)
- Option to triangulate meshes (commit) - (Charles Wardlaw)
- Added an option to import only defined prims (commit) - (Charles Wardlaw)
Weekly Reports
- Aaron Carlisle
- Bastien Montagne
- Campbell Barton
- Christoph Lendenfeld
- Clément Foucault
- Dalai Felinto
- Falk David
- Germano Cavalcante
- Hans Goudey
- Harley Acheson
- Jacques Lucke
- Jeroen Bakker
- Jesse Yurkovich
- Julian Eisel
- Lukas Stockner
- Lukas Tönne
- Miguel Pozo
- Nathan Vegdahl
- Omar Emara
- Philipp Oeser
- Pratik Borhade
- Raul Fernandez Hernandez
- Richard AntalĂk
- Sergey Sharybin
- Sybren StĂŒvel
- Thomas Dinges
- Weizhen Huang
- Wu Yiming
