23 May 2022 (Upcoming - finalized at 18:00 CET)
Welcomes
- Chris Blackbourn is now a dev grant recipient to contribute to the UV editor.
Announcements
- Google Summer of Code 2022: 4 projects accepted.
Modules & Projects
New Features and Changes
Geometry Nodes
- Rename string to curves max width input (commit) (Erik Abrahamsson)
User Interface
- Rename Hue/Saturation node to Hue Saturation Value in shaders and textures (commit) (Daniel Salazar)
- Outliner
- Revert removal of the “Remap data-block usages” operation (commit) (Bastien Montagne)
- Performance improvements
- Significantly reduce memory usage and improve speed of EXR thumbnails (commit) (Harley Acheson)
Curves
- Use only current brush location for delete brush (commit) (Hans Goudey)
- Support pressure in sculpt brushes (commit) (Hans Goudey)
Library Overrides
- Add option to Hierarchy Creation to get all data user-editable by default. (commit) (Bastien Montagne)
Video Sequence Editor
- Remove still frame offsets (commit) (Richard Antalik)
- Delete Strip and Scene Data in one step (commit) (Antonio Vazquez)
- Add new Scene and Strip (commit) (Antonio Vazquez)
- New Change Scene option in Change menu (commit) (Antonio Vazquez)
- Display sound sample rate and channels (commit) (Marcos Perez)
Grease Pencil
- Avoid Automerge with Closed strokes (commit) (Antonio Vazquez)
- Small UI tweaks (commit, commit) (Antonio Vazquez)
- Line Art
EEVEE-Next
- Display error instead of crashing on unsupported hardware (commit) (Clément Foucault)
- Add Velocity module for motion blur (commit) (Clément Foucault)
Subdivision
- Support interpolating orco coordinates in subdivision surfaces (commit, commit) (Brecht Van Lommel, Kévin Dietrich)
Sculpt/Paint
- 3D texturing: Support undo (commit) (Jeroen Bakker)
Python API
- Make Image.save and Image.save_render more consistent with operator (commit) (Brecht Van Lommel)
- Warn that the bgl module is deprecated in the docs (commit) (Brecht Van Lommel)
