2025-04-24 Platforms & Builds Module Meeting
Attendees
  • Anthony Roberts
  • Bart van der Braak
  • Bastien Montagne
  • Jonas Holzman
  • Sebastian Parborg
  • Thomas Dinges
Notes
Blender 4.5 targets
See #136540: Library changes for Blender 4.5 LTS
  • Manifold needs a rebuild with newer hash.
  • HIP-RT needs an update, likely handled by @Sergey
  • OpenImageDenoise will be updated to version 2.3.3.
  • Requests will be updated to 2.32.3 and zstandard will be updated as well.
  • FFmpeg will be updated to 7.1.1 to improve performance in x264 #137670: Deps: Add support for ARM64 assembly in x264 and update FFmpeg version
  • Plan is to land all updates in calendar week 21 (19-23 May). @ThomasDinges will update versions.cmake before with new version numbers.
Bpy/pypi Releases
  • Only main versions are build (4.4.0…) so far. Meeting agrees to build bpy for all bugfix releases in the future.
  • Pypi has a 10GB limit per project. We will ask for a project size limit increase.
  • In the future we may need to remove older versions to stay within the storage limitations. Check statistics (how many downloads for old versions…) before making a decision or ask Pypi people for recommendations (other projects may run into similar problems).
Documentation
Reproducible Builds
  • Would be nice to have at least for Linux, doing this on Windows is impossible with Visual Studio and macOS needs more investigation.
  • Sebastian has a pull request for Linux.
  • Supporting reproducible builds on the buildbot requires more work.
Buildbot
  • 4 new macOS workers with M4 Pro and 64GB RAM have been deployed to production.
  • The macOS machine for benchmarks will also be updated so there likely will be a sudden performance spike.
  • There will be new workers for x64 as well in the future.
Meeting Info
This is a video chat meeting to plan and discuss development for the Platforms & Builds development module. Any contributor (developer, documentation writer, …) working on this area in Blender is welcome to join and add proposed items to the agenda.
Best to hold off on rebuilding Manifold for now. I am discussing another issue with them that may result in a change, and we have a workaround for now to the non-deterministic behavior of the current build.
Current public HIP developer toolkit (ROCm) by AMD for HIP-RT and Windows is 6.2.4, but Blender is using a non public version, thought to highlight that.
Maybe a roll back?
https://www.amd.com/en/developer/resources/rocm-hub/hip-sdk.html
We are using that version for improved RDNA4 support. It is public and can be downloaded from here:
Figured it out finally, the HIP_PATH_63 threw me off…
For Windows you will need various paths for it to work:
HIP-RT 6.4.3
  1. Check if the HIP compiler is on the right version and paths detected first
    hipcc --version
    If it can’t find it or has the wrong version, you will need to update your environment variables
  2. Downlaod and install the AMD HIP-RT optimized SDK
    HIP Ray Tracing - AMD GPUOpen
    The official AMD ROCm (SDK Environment installer) is stuck on 6.2.4, but the installer would have done the paths for you.
  3. Extract to a path witha folder name with no spaces
    Example: C:\AMD\hip
  4. Set the paths in the environment variables of Windows, reboot
    USER variable
    PATH = C:\AMD\hip\bin
    SYSTEM variables:
    HIP_PATH = C:\AMD\hip\
    HIP_PATH_63 = C:\AMD\hip\
    Path = C:\AMD\hip\bin\
