User Interface Module Meeting 2025-04-22T15:00:00Z
Regular User Interface module meeting for planning and coordination. Last regular meeting was April 8th, next meeting on May 6th
Present
- Julian Eisel
- Pablo Vazquez
- Hans Goudey
- Nika Kutsniashvili
- John Kiril Swenson
- Jonas Holzman
- Harley Acheson
Since the Last Meeting
- UI: Filter visible tabs in Properties Editor #115624
- UI: Padding When Opening Menu When One is Already Open #135692
- UI: Region Scaling Edge Highlighting #136337
- UI: Do Not Open Neighboring Menu if Open One is Wide #136528
- UI: Do Not Full Hide Scroll Bars When Region Overlap #136571
- UI: FullScreen Remove Outline and Fix One Pixel Offset #137184
- UI: Increase Gizmo 3D Part Hit Size For Pens #136847
- UI: Minimum Height for Timeline Marker Operations #137312
- UI: Decrease Tablet Drag Threshold With Pen Pressure #136685
- UI: Allow Using Mac Option, Command + Arrow Input Movement #136904
- UI: Use Theme Color for Initial Window Background #137425
- UI: Consistent Pen Tilt Values #137501
- UI: Remove Initial Win32 White Flash During Startup #137488
- UI: Increase Contrast of Scroll Bar Thumb for Light Themes #137618
- UI: Reverse Pen Y Tilt Expected Direction #137636
- Fixes
- Curve status bar stats #137199
- Outliner: Grease Pencil layer visibility icons are grayed out #137641
- #116937: Position and Size ICON_TYPE_VECTOR icons by float #132338
- #137430: Improved Calculation of Minimum Vertical Area Heights #137498
- #136998: Cannot assign shortcut to insert single keyframe operator #137080
- #137365: Do Not Return .notdef for Text Object Control Characters #137374
- #132028: Outliner: Skip search filtering in Lib override hierarchy #137086
- #137186: Allow Event Handling When Cursor Outside Wide Menus #137243
- #137466: Unable to assign shortcuts to âweightâ operators in Weightpaint Mode #137519
- #137391: Do Not Restrict Marker Operations on Region Size #137399
- #137218: Make All Tabs Visible for New Properties Area #137237
Meeting Topics
- Refactor: UI: Split uiLayout functions into separate header files
- Move forward toward the end result of the refactor to the UI layout API, even if some of the intermediate states have compromises.
Review
- Fix #112402: Improve search menu layout #112422
- Harley will continue review.
- UI: Add Drag & Drop Feedback on Windows #107056
- Although this is specifically for Windows, the changes are for all platforms. Jonas will test on Mac.
- UI: Enum Tooltip Item Order #137571
- Gray out the shortcut for consistent styling with menus. Harley will use this as prototype and push forward.
- It would be good to add a flag to RNA properties to say that we shouldnât display the tooltip in the UI because itâs useless.
- UI: Made viewportâs shading modes tooltips more descriptive #137699
- We love it. Small notes for one item. Way to go LoĂŻc Dautry!
- VSE: Change wording for one-time property reports #137579
- Looks good, small wording change requested.
Pen/Touch Related
- UI: Highlight Region Scale Action Zone #136799
- Pablo has notes. We probably want the movement without the opacity change.
- UI: Changes to the Hide Region Widget #118089
- Only agreement is possible the line, but half as long as shown. But might be confusing with scroll bars. Will have to circle back to this later.
Design Discussions
- WIP: Change a numberâs increment on any interface number value via the caret position
- General agreement that we want both this and some sort of âvalue ladderâ eventually, to address both mouse and keyboard workflows.
- There was some disagreement about exactly how the behavior in the PR should work though. That needs some more discussion.
- UI Experiment: Snapping for View3D Sidebar #136575
- We like. Make other similar regions use this snapping function.
- UI: Image Editor Interactive Zoom Control #117050
- Could work for 5.0
- UI: Changes to Save Startup Dialog #134429
- Approved. Simpler and friendly descriptions are wanted.
- UI Experiment: Checkboxes as Switches #137630
- Agreement that there is little need. Looks worse in most cases, except maybe Extensions. So only for large changes. But could be a new toggle type added for 5.0
- General Info on Panels
- VSE: Slip Operator 2.0 #137072
- Questions about clamp behavior when there arenât enough frames to fill the strip
- Consensus was to show a warning in the status bar when the above situation applies (similar to âaffect only locationsâ warning in 3D view), replacing âclampâ option (with vertical bar separator)
- Nodes: Update Default Custom Background Color #137432
- Lots of discussion on this. Seems like a nice improvement.
- UI: Viewport X-Ray modes disambiguation #131032
- Mostly discussion of the proposed icon indicating this state.
- UI: Transparent Armature Bone Selection #131810
- Some discussion.
