2025-03-24 Sequencer meeting notes
Attendees
  • Dalai Felinto
  • John Kiril Swenson
  • Richard Antalik
  • Sergey Sharybin
Notes
  • Offsets for locked strips PR is ready to land.
  • Drop on the preview area if the channel 128 is occupied is does not work very well.
    • Show an error in this case.
  • Editors size and zoom level
    • The idea: when making editor larger – see more channels.
  • Adding strip idea: follow what we do in the node editor: add to the mouse position and enable transform.
    • For the mouse interaction sounds good.
    • How the Esc will behave?
    • What if you add via the editor menu (Strip → Add)?
      • Same, add to the latest mouse position.
    • What happens when you add multiple strips at once?
    • Many things are possible, need the final design task :wink:
  • Richard was mainly doing fixes and refactors.
  • Need Pablo’s review about VSE: Add option to translate pivot point. Dalai might also be interested.
  • John worked on the keymaps re-name to make them readable and understandable.
    • Will run some last round of tests, if they pass the PR will land.
  • John: for clamping handles the Slip operator might need to be refactored (move to C++ etc).
    • There are other improvements John wants to implement for this operator.
  • Proposal: offset the meeting by one week to space out from the UI meeting. Will check with developers in the chat and adjust the Info section accordingly.
Practical Info
This is a fortnightly video chat meeting for planning and discussion of VFX & Video in Blender. Any contributor (developer, UI/UX designer, writer, …) working on these areas in Blender is welcome to join and add proposed items to the agenda.
