2025-03-18 Render & Cycles Meeting
Attendees
  • Brecht Van Lommel (Blender)
  • Christoph Neuhauser (Intel)
  • Nikita Sirgienko (Intel)
  • Michael Jones (Apple)
  • Sahar A. Kashi (AMD)
  • Sergey Sharybin (Blender)
  • Weizhen Huang (Blender)
  • Xavier Hallade
  • Sebastian Herholz (Intel)
Notes
  • For Blender 4.4
    • Hopefully the release is done by the time of the meeting
    • HIP-RT:
      • Moved out of experimental
      • Kept disabled by default for Blender 4.4
  • Other
    • Open backend-specific tasks:
    • HIP / HIP-RT
      • HIP-RT Enabled by default for Blender 4.5
      • Status of shader ray-tracing on gfx12 (report)
        • Is not very wide-spread issue, and with 4.5 does not happen by default.
        • Fixed in the compiler, but maybe some code tweak is possible to avoid us waiting too long. Not the highest priority to find such workaround though.
      • zstd compression of precompiled kernels: would be good if it is supported similarly to the oneAPI. Not high priority either, as kernels are not very huge atm.
    • Support for custom OSL cameras is ready for review
      • Is the stereo support required step for the initial integration?
    • Texture cache
    • Volume rendering
      • Unscattered rays contributing to transparency
      • Tricky part is to get OIDN GPU for command line renders
    • OpenPGL on GPU
      • Has guiding on GPU, training on CPU
      • Working on training on GPU
      • Sebastian will work on some API changes to make further integration easier
      • Sebastian will work on a branch with guided RR
    • Need to patch OpenImageDenoise to support gfx12
      • It currently has some hardcoded arch tests
      • Attila is working on it
    • Transparent shadow and spatial splitting: seems to be an algorithmic issue in Blender, not something that is necessarily specific to the HIP/HIP-RT.
Practical Info
This is a weekly video chat meeting for planning and discussion of Blender rendering development. Any contributor (developer, UI/UX designer, writer, …) working on rendering in Blender is welcome to join and add proposed items to the agenda.
