Date/Time: 2025-03-03T15:00:00Z
Link: https://meet.google.com/xxo-tyin-rem
Attendees:
- Amélie Fondevilla (Developer, Les Fées Spéciales)
- Antonio Vazquez (Developer)
- Casey Bianco-Davis (Developer)
- Falk David (Blender)
- Samuel Bernou (Python Dev, ADV studio)
- Thomas Dinges (Blender)
- Wu Yiming (Developer)
Topics
- Development updates
- Discussions
Meeting Notes
- Blender 4.4 is going into the release candidate stage next week! Please test it out, and if you find issues, please report them. Thank you!
- Most development efforts went into bug fixes.
- Falk: Is working on a prototype that changes the way artists work with Stroke/Fill settings #135307 - WIP: Grease Pencil: Remove Stroke/Fill setting from materials - blender - Blender Projects.
- Plan is to create a feedback thread (here on devtalk) with more detail soon.
Show all commits
- Fix #129967: Annotations in the VSE not showing in Dope Sheet by Christoph Lendenfeld
- Fix: Grease Pencil: vgroup_select operator not working by Pratik Borhade
- Curves: Separate to object operator by Hans Goudey
- Brush Assets: Add Material to linked editable assets by Brecht Van Lommel
- Refactor: Simplify grease pencil brush material API surface by Brecht Van Lommel
- Grease Pencil: Make brush asset pinned materials local by Brecht Van Lommel
- Fix #134808: Grease Pencil: Interpolation tool crashes when stroke has zero length by Lukas Tönne
- Fix: Grease Pencil: “Extrude” operator breaks vertex group weights by Janne Nylander
- Fix #134898: Grease Pencil: Select Similar doesn’t work in stroke mode by Pratik Borhade
- Fix #134843: Grease Pencil: Crash duplicating active keyframe by Pratik Borhade
- Cleanup: Grease Pencil: Remove unused drawing vector by Pratik Borhade
- Fix #134482: Grease Pencil: Interpolation creates uninitialized values by Lukas Tönne
- Fix #134969: Grease Pencil: Ensure correct mode for image tracing by YimingWu
- Fix #134809: Grease Pencil: Proportional edit tweaks locked material strokes by Pratik Borhade
- Fix: Grease Pencil ID data evaluation happening in the wrong function by Falk David
- Fix #135052: Grease Pencil: “Convert To” missing in object context menu by YimingWu
- Fix #134793: Grease Pencil: Set Uniform Opacity cannot set fill opacities by YimingWu
- Grease Pencil: Channel color for groups by Pratik Borhade
- Fix #134810: animating Grease Pencil layer “hide” option doesn’t un-hide by Sybren A. Stüvel
- Grease Pencil: Remove legacy object type references by Pratik Borhade
- Fix #134984: Grease Pencil: Applying a modifier clears keyframe of hidden layer by Falk David
- Fix #134489: Grease Pencil: Simplify operator should follow selection by YimingWu
- Fix: Grease Pencil: Add channel_color RNA prop to layer groups by Pratik Borhade
- Fix #135313: Grease Pencil: Layer adjustments get applied repeatedly during playback by Falk David
- Fix #135163: Grease Pencil layer visibility animation doesn’t work in NLA by Sybren A. Stüvel
- Casey: Is wondering if the boolean cutter could still be useful even if it can’t create holes yet.
- Falk: Yes. Even without support for holes (and maybe not super optimal performance) a cutter tool for fills would be very useful for many artists.
Next Meeting
- Time/Date: 2025-03-18T15:00:00Z (not a Monday, but Tuesday!)
