2025-01-07 Nodes & Physics Module Meeting
Check the overview thread for more information about the meeting.
Present
  • Jacques Lucke
  • Simon Thommes
  • Hans Goudey
  • Iliya Katueshenock
  • Andrew
  • Mattias Fredriksson
Since the Last Meeting
Meeting Topics
  • Should realize instances adjust point radius based on instance scale?
    • The radius should be adjusted, for curves and point clouds, but the node should have a legacy option for compatibility (in the sidebar).
  • Spreadsheet: Move context path to footer, add editor menus
    • The space where the context path is should definitely be the menus.
    • But pinning is strange to have in the bottom left.
    • It would be good to get Dalai’s opinion, maybe he has ideas about how to redesign the context path to be vertical in the sidebar.
  • Mesh: Add “free” custom normals
    • The PR should have more information about performance to make a better case for the free normals.
    • Otherwise the PR seemed in a good state.
  • Node active vs. selected status (report)
    • This is a global problem in Blender, where things can be unselected but active (Stronger binding of Active and Selected).
    • Blender’s selection/active handling should be consistent, so we can’t just change the behavior for the node editor.
    • Maybe there could be some way to indicate that a deselected node is active.
