Attendees
- Omar Emara
- Sergey Sharybin
Notes
- The new CPU compositor replaced the old one!
- 40k lines of code is pooooof!
- Now we have single compositing system, which has all sort of benefits.
- Omar is working on the performance improvements
- The meeting went into discussion of the transform realization. Main points
- Implement repetition - as part of realization
- Current realization has stability/precision issues. Possible solutions
- Delay realization until filter node
- With the side-effect of mix/alpha-over behaving differently due to pixel-processing nature
- Omar will prepare a PR so that it can be tested before landing
- Offset after rotation to improve sampling
- Failing GPU tests:
- Not really a new issue. Maybe got worse after the driver update on the test system.
- Short term: either donโt use EWA in tests, or disable tests of GPU
- Both approaches have cons/pros
- Omar will look into it and see what is the best
- Long term: approximate own EWA implementation (donโt rely on hardware)
Practical Info
This is a fortnightly video chat meeting for planning and discussion of VFX & Video in Blender. Any contributor (developer, UI/UX designer, writer, โฆ) working on these areas in Blender is welcome to join and add proposed items to the agenda.
- Google Meet
- Google Calendar Event
- Next Meeting: January 14 2025, 12:00 to 12:45 PM Amsterdam Time (Your local time: 2025-01-14T11:00:00Z)
