Attendees
- Nikita Sirgienko (Intel)
- Sergey Sharybin (Blender)
- Sahar A. Kashi (AMD)
- Thomas Dinges (Blender)
- Lukas Stockner (Blender)
- Patrick Mours (NVIDIA)
Notes
- For 4.3
- Reminder: beta is in 2 weeks
- Add ability to control hardware raytacing #125082
- Now to test HWRT
CYCLES_TEST_DEVICES
needs to be set toMETAL-RT
,ONEAPI-RT
,HIP-RT
. - The goal is to enable tests for both configurations on the buildbot
- Now to test HWRT
- Performance regression #127464
- Sahar will check on Windows, it could be related on the HIP version used
- It should be safe to update to 6.1 now
- Linux HIP-RT #121050
- Build system is landed
- Waiting for platform maintainers to commit libraries
- After that the rest of the change will land
- Lunar Lake GPUs will be enabled for 4.3
- There might be a value of adding it to 4.2 as well. Depends on the scope of the change
- Weizhen and Lukas are looking into phase functions patch
- Seems safe for 4.3
- We’ll run benchmarks closer to the merge
- OptiX 7.4 (still) needs deployment to the builder machines
- Some other way got in a way. Hopefully can happen this week.
- Other
- Cycles: various curve rendering issues #124295
- Previous meeting discussed alignment to GPU
- Will check with the studio artists to confirm its fine
- Cycles render test: Failing oneAPI tests 125088
- Nikita will check if increasing samples properly converges
- Lukas is working on temporal denoiser
- he reached out Attila, to align the work
- Will continue research from our side, and share the current data-set used for training
- Lukas is looking into OIIO for all formats
- Added full JPEG netadata support in OIIO (it only supported a single comment block)
- Looking into implementing OpenEXR multipart file support
- In the future we might need to use “blender:” prefix for EXR metadata to avoid conflicts
- Once the OIIO is updated on our side it will bring Jpeg XL support
- Lukas did preliminary tests with AVX-512 on Xeon 8480 56 cores dual-socket
- On Blender side there is no benefit (with the corresponding compiler flags, surely)
- With Embree there is few percent speedup. Could be better with ray streaming, but it needs to be implemented in Cycles.
- Need to check with CPUs from AMD, which now also come with AVX-512
- Sahar points out that
wmic
(used in OpenData) is deprecated- Xavier run into similar issue
- Maybe the solution is to use something completely different, as long-term it doesn’t seem we can rely on this utility
Practical Info
This is a weekly video chat meeting for planning and discussion of Blender rendering development. Any contributor (developer, UI/UX designer, writer, …) working on rendering in Blender is welcome to join and add proposed items to the agenda.
- Google Meet
- Google Calendar Event
- Next Meeting: October 1 2024, 5 to 6 PM Amsterdam Time (Your local time: 2024-10-01T15:00:00Z)
