Agenda
- What exactly is the problem?
- What is the preferable solution?
- How long would this take?
- Who can work on this?
- When can this be prioritized?
Attending
- Bastien Montagne
- Sebastian Parborg
- Sergey Sharybin
- Simon Thommes
- Sybren Stüvel
Problem
- Flamenco uses BAT for packing all dependencies of a job, which analyzes the .blend file separately from Blender and does not properly take nested dependencies into account.
- So far this has not been a problem, since BAT did still catch all dependencies due to how Blender references (/referenced) nested dependencies directly
- With recent refactors this is becoming an issue with dependencies that are missing from the pack
- More problems will continue to come up with how BAT is analyzing dependencies without loading the .blend files
Proposed Solution Options
- Use Blender internal functionality for packing in the Flamenco Addon instead of BAT ( → long term)
- Make BAT use Blender’s internal dependency information for packing, rather than relying on independent analysis ( → short term)
- Implement recursive dependency analysis in BAT
Meeting Outcome
There is a preferable long term solution to stop relying on BAT, since currently this continuously put the burden on keeping up with Blender development to find all necessary dependencies.
Since sufficiently implementing this solution would require a large effort of core development regarding multiple different big topics, this is currently not a feasible target to be prioritized.
There is a sufficient short term solution to keep using BAT but replace collecting the dependecies by exposing existing Blender functionality to the python API and using the active Blender instance when submitting a job with Flamenco.
Short Term Solution
(within few months)
- we keep using BAT for remapping and editing the paths without loading the files
- Bastien exposes existing filepath iterator system to python API (few days of work - either still before holiday or right after)
- Sybren implements Flamenco (python) functionality to pass information about dependencies and filepath remapping from Blender’s already loaded instance when submitting a job to BAT
Long Term Solution
(big breaking changes for upcoming series or beyond)
- Avoid the necessity of using BAT as a separate system that needs to be kept up-to-date with any Blender changes
- Add required functionality to Blender itself
- Avoid building viewport depsgraph on file-load with command line execution (for performance when recursively going through libraries)
- Consistent pointers for hashable blend files (for shaman)
