Attendees
- Omar Emara
- Sergey Sharybin
Notes
- The new CPU compositor is in state where developers can work on porting nodes implementation.
- The simple Image → Output configuration should work
- Other nodes needs to be adjusted to work
- Omar is looking into compiling operations to either shader or multi-function
- Aligning implementation allowed to utilize debugging tools, such as memory leak detection. Some issues has been found, and will be fixed soon.
- The meeting discussed the Use Alpha setting in the output nodes. It is confusing from user side, and complicates some internal implementation.
- Current suggestion is to replace Use Alpha and Alpha socket with Set Alpha operation, which has better control on how alpha is actually being modified
Practical Info
This is a fortnightly video chat meeting for planning and discussion of VFX & Video in Blender. Any contributor (developer, UI/UX designer, writer, …) working on these areas in Blender is welcome to join and add proposed items to the agenda.
- Google Meet
- Google Calendar Event
- Next Meeting: September 10 2024, 12:00 to 12:45 PM Amsterdam Time (Your local time: 2024-09-10T10:00:00Z)
